I have built, tested, and had fun with these subs, they sound great, and I have only been running 1 at a time in a 2cf sealed box inverted.
The specs show they would do great in a 6cf box and larger.
Dual 2 tested at 3.98 ohms in series
Fs is 19.5hz
Qts 0.164
Qes 0.166
Qms 12.75
Bl 50.06
VAS 10.45cf
Le 5.5mH
93db efficiency 1w 1meter
18mm 1 way linear capable to push some series air
copper coil 21gauge wire 4 layer
800rms easily
I have been disappointed with Bass box 6.0 pro lately, because it says these subs play best in 20cf box with small port area, but thats a disadvantage of using a high BL factor sub in a speaker box program- High BL subs will always play better in smaller boxes than larger boxes. Iam sure sealed these boxes will slam in the 6cf area, and ported 8-10cf tuned low- Perfect Pshyclone subs or home audio
2cf sealed, they sound great! each sub of course, just need more power
They run about 50lbs each
Heres some pic's
These are freshly built, brand new, perfect condition, if your in the area, come take a listen!
$250 each- not shipped
$420 pair
Edited by Forevrbumpn
Bumpppp
Friday bump! no buys these Im gladly using them
This topic is now closed to further replies.
