4 Soundstream 12's In A Standard Cab Dime
the console is looking like it will work this time. the last two attempts were failures. also orderred some Knukon 1/0 wire for big 3 upgrade. also ordered some 1/0 rings, a fuse holder and 300A fuse for it, my first time doing a big 3 upgrade. looking forward to it.
Current System:
Pioneer 6900 HU
Front Stage: (for now)
Soundstream tarantula 5.25 in the doors
Soundstream tarantula 4x6 in the dash
Kenwood 400.4 for mids & highs
Bass:
4 Soundstream RW-12's
2 Power Acoustik Stax 4000/1D's
single chamber box, 2.65 cubes.
Currently under the knife being bagged
Rebuilding err'thang
So I recently got some more parts. my wire for the big 3 came in as well as my other stuff for putting it in. I got started tonight but after 4 hours I still have some more to do. I also got some more done on my center console.
Threw on this on just because I had it :) check out those sweet late 80's el camino buckets!!!
Posted Image
Posted Image
Posted Image
Posted Image
I added sides to my console and got them glued up, hopefully ill make the top later today and get the amp rack started.
Posted Image
Posted Image
Big 3
Posted Image
Im gonna mount all my fuse holders over top of my overflow bottle
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
I got it almost done but i need another battery post for the negative terminal bc i bought the wrong one :(
Posted Image
More to come tomorrow, I cannot wait to hear this for the first time
http://www.stevemeadedesigns.com/board/public/style_emoticons/default/hairtrick.gif Maybe?
Current System:
Pioneer 6900 HU
Bass:
So today went pretty well i guess. I thought this build might get some more intrest for some reason, but im completely psyched about it. maybe its bc i havent had bass in a week and a half! idk. I got the right battery terminal today too, so my big 3 will be complete!
I got my mounting plate for my fuse holders finished up, it turned out better than i thought.
Ill have one more ANL fuse holder going on there, and check out the sweet wire loom zip tied around the edge.
Posted Image
Posted Image
Posted Image
It made a difference, 14.23 volts at the battery now :)
Posted Image
Also got hinges and a lid on my console
Posted Image
Posted Image
Posted Image
Posted Image
Current System:
Pioneer 6900 HU
Bass:
So last night I got some screws for my fuse mounting plate, the right battery terminal and some dampers for my console bc that lid closes fast lol.
Posted Image
I put the terminal in and got my ground wire hooked up
Posted Image
Checked the voltage at the battery again, it was at 14.36 for a while but stayed at 14.33. this should be fine until i can get a new battery for under the hood and a HO alt.
Posted Image
Current System:
Pioneer 6900 HU
Bass:
Did a little bit already today.
Got dampers on the lid
Posted Image
Made the amp rack and notched the pieces to run my ground wires through to keep them short.
Posted Image
Posted Image
im working on a pod to mount my faze voltage gauge in and hopefully by tonight the console will be almost complete.
Current System:
Pioneer 6900 HU
Bass:
Looks very nice i like the Designs for the amp's It will look sick once it's done. Also the Console will be looking fresh as well.
Thanks. space is really tight so its all I could come up with. Its my first console so im making it up as i go, the only way to learn is to try. Ill have more pics tonight. its coming along nicely.
Current System:
Pioneer 6900 HU
Bass:
Iv almost got the console finished now. All it really needs is some wiring, an armrest, and some form of covering.
I made the front piece of my console and made a gauge pod and got it mounted
Posted Image
Posted Image
Posted Image
Ran 8 gauge into the console for power to the accesory switches that will be mounted inside
Posted Image
Got the amp mounted and ran my remote wire and rca's
Posted Image
Posted Image
Night shot of the gauge
Posted Image
Current System:
Pioneer 6900 HU
Bass:
Its finally all coming together. I got my console wired up, mounted the amp, made up the first set of speaker wires, and started cleaning all those wires up. Im def gonna need a small false floor built in front of the box to hide all these wires. and to mount my fuse and distribution blocks too.
Iv still got to build an armrest/wire cover to go over top the amps, make a mounting plate for the line driver, and im going to finish the console with the bedliner used to finish the box. all I need now is another amp, some wire, and meh batteries.
power and ground lug in console
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
Current System:
Pioneer 6900 HU
Bass:
looks pretty sweet
i was thinking leave the 12 sitting in the box in the hole and duck tape from the bottom of the sub to the bottom of the baffle so the sub doesnt free air. would that work?
