1954 Bel Air Trunk
If your not to far along you really should start with the floor first. Building and setting the panels on a flat even surface will make things easier. If your going to cover where the bottom panel's edges meet the sides you dont need to be as precise with the angles. There are a couple of methods to meet weird shaped panels. One is just like your doing. Cardboard, marking with a pencil, cut, check and repeat until your happy. You can do even smaller sections and tape them all up into a pattern and transfer to a piece of wood. There are contour gauges that you can find at woodworking sites that work great. Some are flexible rubber guides that can be molded onto complex shapes to transfer the contour to a template. There is also a push thru wire type that does a good job as well.
What your doing is looking good so far so just keep it up and Im sure it will turn out well.
thanks... that's what i needed to know.. and thanks for the tools tip, gotta check them out too.
as for the floor board, how thick of a wood should i use? and which one? mdf or plywood?
The Project!!
1954 Trunk Build
http://www.stevemeadedesigns.com/board/topic/102529-1954-chevy-belair-trunk-build/
The Daily!!
Head Unit: Alpine 9883
Subwoofer: 2 12's DC Level 4 XL
Amplifier: New DC 3.5 K
Rear Center Console: 1 8' DD 1508
Amplifier: Rockford fosgate 500
Mids and Tweets: Beyma tweets
e36 Trunk/Subwoofer Build
http://www.stevemeadedesigns.com/board/ind...showtopic=27903
the front view... my friend just finished pinstripping it.
Edited by dunkoholic
The Project!!
1954 Trunk Build
The Daily!!
got a question fellows... im about to make my floor board... and i was wondering how thick of a wood should i use for the floor board? 1/4 or 3/4 mdf/ plywood?
The Project!!
1954 Trunk Build
The Daily!!
I would just use 3/4" mdf should be stiff enough
cool, thanks for the quick reply.. time to run to home depot..
The Project!!
1954 Trunk Build
The Daily!!
I would make a false floor and cover the tank 1/2 way and put the compressors so they stick out of the floor on an angle. I have a pic of some thing simular to this I will see if I can find it
sup bro, did u ever find that pix... like to see what your talking about..
The Project!!
1954 Trunk Build
The Daily!!
My original plan was to run hardlines like this...
But money is kinda tight, so i decided to flip the tank so you wont see any hose/lines..
but come to find out that if i ran the hose from underneath, my gas tank got in the way...... SOOOOOOOOOOOOO
I decided to flip the tank around again, and came up with this... it clears the tank perfectly... :spiteful:
The Project!!
1954 Trunk Build
The Daily!!
i decided to put plexiglass mirror on the bottom just because..
and here it is glued in... now i have 4 10's :spiteful:
The Project!!
1954 Trunk Build
The Daily!!
  • Who's Online   1 Member, 0 Anonymous, 1731 Guests (See full list)
