Turkator Posted May 20, 2009 Report Posted May 20, 2009 Bridge both channels of a 4 channel amp and run 1 channel to each coil of a DVC sub? Will it hurt the sub or amp? Thanks for any help
Boon Posted May 21, 2009 Report Posted May 21, 2009 It's ok with 99% of 4 channels. There are a few that you can only bridge the 'rear' channels on, especially some Alpines. If your amp gives a power rating at 2 x something then you're good to go, as long as the sub is Dual 4 ohm. If it's dual 2 ohm then your amp will see 1 ohm per channel and might let the magic smoke out. 10.x volts fo' life!
