velcroslap Posted May 27, 2009 Report Share Posted May 27, 2009 (edited) sound deadener and space. Edited May 27, 2009 by velcroslap Quote * Head Unit: Kenwood KDC-MP732 * iPod Interface: KCA-iP500 * Front Stage: Rockford Fosgate Power T1652-S * Front Stage Amp: Rockford Fosgate Punch P400-2 * Rear Stage: Alpine SPR-13C Type-R 5-1/4" * Amp: Rockford T10001bd * Subs: (2) 15" Rockford P3s * Front Battery: Optima RedTop * Back Battery: Kinetic Hc2400 * Wiring: Rockford 1/0 * Big 3: Rockford 1/0 * Enclosure: Idyllic Link to comment Share on other sites More sharing options...
enemyofsilence Posted May 27, 2009 Report Share Posted May 27, 2009 (edited) you also need time and mulah : Edited May 27, 2009 by enemyofsilence Quote Team Bass-Hz Link to comment Share on other sites More sharing options...
RamenNoodles Posted May 27, 2009 Report Share Posted May 27, 2009 Low voltage + clipping = BTL death. You would want an amp that will do around 2500 rms daily. You can throw more at it, but in your case, you should just keep it on the lower end. I would say a nice battery up front and at least 1 group 31 battery in the rear with around 2+ runs of 1/0, big 3 in 1/0, Alt power of at least 150A and a nice signal processor. Running a BTL or any higher powered subwoofer is not easy if you dont know what you are doing, and not cheap either. Quote Diablo Audio Technologies Fi Car Audio Ascendant Audio Link to comment Share on other sites More sharing options...
MikeH683 Posted May 27, 2009 Author Report Share Posted May 27, 2009 a 2000wrms amp, 1/0 gauge wiring, batt or two in the back, possible HO alternator. oh and at least a 5cuft box What are legitimate amps to use that puts out that much wattage? Quote Link to comment Share on other sites More sharing options...
enemyofsilence Posted May 27, 2009 Report Share Posted May 27, 2009 (edited) What are legitimate amps to use that puts out that much wattage? saz 3000d DAT 2500 RF T4000 just some i can think of right now Edited May 27, 2009 by enemyofsilence Quote Team Bass-Hz Link to comment Share on other sites More sharing options...
RamenNoodles Posted May 27, 2009 Report Share Posted May 27, 2009 Im kind of in favor of the DAT 2500.1 Pm me for more information on the amp lineup. Quote Diablo Audio Technologies Fi Car Audio Ascendant Audio Link to comment Share on other sites More sharing options...
Bali Posted May 27, 2009 Report Share Posted May 27, 2009 yah just get a bl, they bang with the right enclosure. Quote Link to comment Share on other sites More sharing options...
tudski Posted May 27, 2009 Report Share Posted May 27, 2009 yah just get a bl, they bang with the right enclosure. sorry sir but u do not have the right enclusure. but for the OP i would say 15 BLs would be really nice, but if u want to go with 18s i say do a blow through. Quote 1996 deville on 18" full face rims -2 gauge wire. -a2400db -RE SE-X in a 4ftc box tuned to 32hz -tview touch double din -rockford punch 6x9s(rear) -mtx 6.5(front) front and rear stage will soon be changed build log will start as soon as it aint cold! Link to comment Share on other sites More sharing options...
MikeH683 Posted May 27, 2009 Author Report Share Posted May 27, 2009 sorry sir but u do not have the right enclusure. but for the OP i would say 15 BLs would be really nice, but if u want to go with 18s i say do a blow through. What you mean a blow through? Quote Link to comment Share on other sites More sharing options...
tudski Posted May 27, 2009 Report Share Posted May 27, 2009 (edited) What you mean a blow through? the sub box goes into your bed with a teanou(sp?) cover and you cut a hole from the bed to the cabin behind the seats.. easier said then done.. but when done right it sounds nice and looks good stealth edit: but with a truck like that im sure you would cry cutting it up ahaha. not something to do if u dont know wat your doin. if u have any reputable shops around u have them take a look. Edited May 27, 2009 by tudski Quote 1996 deville on 18" full face rims -2 gauge wire. -a2400db -RE SE-X in a 4ftc box tuned to 32hz -tview touch double din -rockford punch 6x9s(rear) -mtx 6.5(front) front and rear stage will soon be changed build log will start as soon as it aint cold! Link to comment Share on other sites More sharing options...
