Before you go the cam route start with the basics...
1. Intake (which you already got)
2. Headers ( equal length gives more torque which is what you want on the street)
3. a carb spacer (one inch four hole, going from no spacer to an open spacer gained me one tenth. But going from a open spacer to a four hole was a tenth and a half. So I gained 2.5 tenths from a 35 dollar spacer).
4. bump your timing up by 2 to 4 degrees
5. Carb jetting will gain good hp and mpg
Doing all of this I went from 14.7 to 14 seconds in the quarter.
Once you do all that, then its time for a set of heads, then cam.
If you build it, db's will come...
NSPL World Record Holder Trunk 0-1800 watts---147.9 with 1722 clamped watts @ 40Hz(9-20-09).
Competition Only Record Holder Trunk 0-500 watts---148.1
2006 Nissan Altima 3.5 SE
Currently Rebuilding....
My 150db Plus Trunk Build
I do box designs.
[benH] 6:24 pm: clipping doesn't really hurt subs
[benH] 6:24 pm: being an idiot is what blows subs
what do you mean by carb jetting i know how a carb works i have just never changed parts on one when i slam it to the floor from a dead stop it stumbles or backfires and its a completely new Holley 600 cfm carb with no adjustment
cam and headers and you could probably get another 50hp (depending on the cam) but you should just get a 350, or sell the whole car and buy a Mopar :P
1990 Jeep Cherokee 4X4
Pioneer DEH-P2900MP, Big 3 done in 1/0, 1 run 1/0 ran to amp
DAT HF1000.1 #007 powering a DC lvl4 15
DAT HR 4085 prototype powering 2 Selenium 6s and 2 no name tweeters running active
1st place in AS3 @ Surf City Sound Off, 140.8 @ 45hz @ the headrest.
rebuild coming soon to get a better score :)
"I regard the brain as a computer which will stop working when its components fail. There is no heaven of afterlife for broken down computers; that is a fairy story for people who are afraid of the dark."
There are adjustments...
idle/air, jetting, squirter, vac secondary
Carb jetting = the "jets" inside the carb controls the amount of fuel used. Holley's are normally fat right out of the box (meaning to rich, to much fuel).
The stumble or backfire is from the squirter curcuit.
I would tell you to look up all the carb tuning you can.
I do box designs.
holleys have jets that you change. they have primary's and secondary's. also it looks to be a vacuam secondary card, you can change the diapraghm in the accelerator pump housing. you can fit full length headers on there but ground clearence is an issue. bein a 305 the bore is small so by putting a larger cc head on there hurts you more then helps you. you lose compression. thats a good thing if your going to force feed the motor with massive amounts of air. but if your going to keep it n/a then you dont want to lower the compression
2000 gmc yukon
4 sundown Zv3 15's
4 dd m2a's
kenwood kdc-x994
2 batcap 4000's 1 batcap 2000
dual alts.
154@37hz and climbing
http://www.cardomain.com/ride/3231683
http://www.myspace.com/torque150
im just looking to build it up to be one of the fastest cars at my school the only two supposedly fast cars are a 2000 stock v8 camaro and a b18 honda civic
Buy a one inch 4 hole carb spacer, see if you notice a difference. It may also help your stumbling issue.
I do box designs.
