fast85_gt Posted May 30, 2009 Report Posted May 30, 2009 ok right now my box is 9.99cubes gross after port and sub displacement im arournd 8cubes net with a 100sqin of port 4"x25"x21.5" deep tuned to 31or 32hz i dont know what i need to know is how deep do i need to make my port tuned higher around 35hz or so so i can get better numbers at comps, im running 2 18" treo ssx 18's and 2 rd audio 3250.1's the box was built to treo's spec's
bkolfo4 Posted May 30, 2009 Report Posted May 30, 2009 Assuming 8 ft^3 net with the 21.5" port, you could cut the port down to 16" long. That would give you around 8.35 ft^3 net tuned to 35 Hz. If you want to stay at 8 ft^3 net, make the port 17.25" long and add corner fill somewhere to take up abuot 500 in^3. Not much port area if that is 100 inches for the pair of 18's. Brian Current system: 1997 Blazer - (4) Customer Fi NEO subs with (8) American Bass Elite 2800.1s Previous systems: 2000 Suburban - (4) BTL 15's and (4) IA 40.1's = 157.7 dB at 37 Hz. 1992 Astro Van - (6) BTL 15's and (6) IA 40.1's = 159.7 dB at 43 Hz.
