Rogers Posted May 31, 2009 Report Posted May 31, 2009 ok so since i traded my type s's for 2 type r's im going to be buying 2 more and i might as well get my box design out of the way... an eclosure for 4 12" type r's so the type r's need 1.3cuft net each... so thats 5.2 net alltogether im going to do (4) 4" round ports x 18" long = .44cuft displacement should be 35ish hz the driver displacement is .07cuft per sub = .28cuft so i end up with a total displacement = .72cuft displacement so my gross enclosure volume needs to be = 5.9cuft so im going to do subs up ports back again... so im thinking my demensions will be... 33"wide x 15"tall(double baffle) x 27" long making my internal deminsions 31.5"wide x 12.75"tall x 25.5"long =5.92 gross let me know if im off..... http://www.stevemeadedesigns.com/board/topic/79921-rogers-700-dream-car-update-page-17-a-wall/?p=2335774 93 Saturn SC2My system4 SA-15's Walled 2 Cerwin-Vega S2000's 3 Kinetik Hc2000's Dual 200amp alts. you guys done with the peepee touching contest or do I need to end it?
bkolfo4 Posted May 31, 2009 Report Posted May 31, 2009 You got it. . . Current system: 1997 Blazer - (4) Customer Fi NEO subs with (8) American Bass Elite 2800.1s Previous systems: 2000 Suburban - (4) BTL 15's and (4) IA 40.1's = 157.7 dB at 37 Hz. 1992 Astro Van - (6) BTL 15's and (6) IA 40.1's = 159.7 dB at 43 Hz.
Rogers Posted June 1, 2009 Author Report Posted June 1, 2009 You got it. . . you taught me man....thanks! i havent decided if im going with this enclosure or if im going to do a slotvent, if i do a slotvent im not sure how wide to make my vent... http://www.stevemeadedesigns.com/board/topic/79921-rogers-700-dream-car-update-page-17-a-wall/?p=2335774 93 Saturn SC2My system4 SA-15's Walled 2 Cerwin-Vega S2000's 3 Kinetik Hc2000's Dual 200amp alts. you guys done with the peepee touching contest or do I need to end it?
bkolfo4 Posted June 2, 2009 Report Posted June 2, 2009 You will see the general rule 12-16 sqin of port per cuft of enclosure. This normally works out, but port area is really determined by the air velocity moving through the port. If I have a 7 cuft box for an 18" driver and I put in a low excursion driver and a 500 watt amp, that is not going to require as much port area as an 18" BTL on 4000 watts. . .Not that it will hurt to have more port area on the low power setup, it is just not a must if space is an issue. I use this for my box designs: http://www.carstereo.com/help2/Articles.cfm?id=31 Slot ports are as easy to calculate as round - same method - just watch out when the length gets the port wall too close to the back wall. Brian Current system: 1997 Blazer - (4) Customer Fi NEO subs with (8) American Bass Elite 2800.1s Previous systems: 2000 Suburban - (4) BTL 15's and (4) IA 40.1's = 157.7 dB at 37 Hz. 1992 Astro Van - (6) BTL 15's and (6) IA 40.1's = 159.7 dB at 43 Hz.
