Posted (edited)
Well today i started working on my electrical!
Picked up a cheap scoche terminal block.
Ran a line of 4g from the alt to the bat +, will leaving the stock line also hooked up mess with anything?
Ran a new ground from the bat.
All my fuse blocks.
Three inchers installed in armrest.
Kendwood headunit that someone threw away because it had brocken rca solders on the board. I fixed it!
Edited by BHSskaterBHS
2002 FORD EXPLORER PACKED WITH SOME CHEAP SUBWOOFERS!
Chasis to engine block ground?
Passport Build Here
Alarm: Prestige APS997A 2-Way/Remote Start
HeadUnit: Pioneer DEH-P6000UB
Front Battery: Yellowtop Optima D34/78
Back Battery: 2x C&D Technologies High Rate Series UPS12-475FR 134AH
Subs: 2x DC Lv4XL 18's
Amps: 2x Sundown Saz1500's Strapped
Box: 12Cubes 33hz 185sqin Port(15.4sqin per cube)
Pillars: AudioBahn AS31Q
Front Doors: Clif Designs TX40.5
Back Doors: Clif Designs CD50.4C
Rear Speakers: Clif Designs TX46.5
Front/Rear Amp: Kicker ZX350.4
Back/Pillars Amp: Kicker ZX200.2(Looking for another zx350.4)
Electrical: 1/0 Scorpion Wire 2 Runs Pos and 2Runs Ground, Knu 1/0 Flex Running to Amps ect, Big 3, JL 8Ga For Speaker Wire, Knu Karma RCA's, Scorpion Volt Meter
Deadener: 100 sqft Sound Destroyer Mat And SECOND SKIN Damplifier Pro Door Pack
:8) Speakers in armrest?
Vehicle: 2001 Ford Escape
Head Unit: Kenwood Kdc-x592
All out for a rebuild.
New shit coming in the next 30 days.
had a load of 4g because that what my amp needs, so i used it. its very good wire and dont plan on moving to 0g, im only running one amp so i think im fine. the center console can be put back where the 3 incher are, its a stick so i dont use it anyways. and i still need do alt to chassis
is there supposed to be a fuse block on the wire going from to positive to the alt? and could i just disconect the original wire from the pos to the alt?
