rrims Posted June 4, 2009 Report Posted June 4, 2009 Ok, so here's my story. I went out yesterday and bought the JVC KDR300 from Bestbuy, bought the Harness, and the mounting brackets. I came home and while looking at the wires in the dash for the radio (i bought the car with no radio, and someone before me had an aftermarket one in there, so no wiring harness was in there when i got it) i came to find that i do not have a constant hot wire to connect to the radio. So now here's my question, how would i go about getting a constant hot wire, or how would i run a new hot wire. I have an accessory wire already, that is hot when the key is on, and i have a good ground, but that is my only problem. So can someone bare with me on this installation please, its my first time on my own wiring a headunit.
Jville140db Posted June 16, 2009 Report Posted June 16, 2009 sounds like you need to check your fuses first may not even be labeled radio so check them all if you are unsure on how to use a meter take them out one by one and check them visually. Car is 2010 Scion Tc Currently in car Deck- Sony XAV-60 in-dash mobile video system Speakers- Rockford Punch 6.5in comps in the front and coax in the rear Subs- 2 Gen 3 Rockford P3 12's dual 4 ohm Amps- Rockford P1000-1bd and P400-4 Alpine Mrp-f300 is in for P400-4 which is out to service Wiring- all rockford nuff said Enclosure- Dual 12in custom box by SRQ Battery- Optima Yellow top with big 3 done Sound Damping- All Dynamat products 1-2 layers throughout with liner on top Link to my build log- http://down4sound.co...=newpost&t=5275 Link to my youtube- http://www.youtube.c...ser/Jville140db MECP Advanced CEA # 110531 BassBox 6 Pro for Box Building/Re audio box calculator If you can hear the passenger it aint loud enough!!!!!!! QUOTE (MickyMcD @ Sep 25 2009, 07:25 PM) "My system has 30 speaker terminals, that means shits wanging doggggg....."<!--QuoteEnd--></div>
