bigg_will Posted March 14, 2007 Report Posted March 14, 2007 is there any way to wire up two amps in a series to 2 subs in parallel? i might be wiring up this tonight if possible. this guy has 2 amps and 2 subs and was hoping to get it a little bit louder and i just wanted to check on here if this setup was something that could be done before i fucked something up. thanks 2002 Chevy Blazer 2 door 1-18" Fi BTL, 1 T2000.1bd, 8 ft box before displacement tuned to 33Hz, Big 3 done in 1/0 Havent been metered yet
majorpayne Posted March 14, 2007 Report Posted March 14, 2007 you cant wire two amps in series, only parallel, you could either do 2 runs of whatever gauge power wire you are using and two grounds and run them to both amps or you can use a distrobution block and split the first power wire into two leads and do the same with the ground also. What amps are these? are they strappable? that would be you best bet. If not just hook up both amps and set them the same all they way around ie phase, ssf, lpf, all that stuff and set your gain with a dmm so both amps read the same output voltage. sorry for the long response, hope that helps. Wes
