Boon Posted June 9, 2009 Report Posted June 9, 2009 Remember the critical rule of resonance - if you peak at 30hz, you should also peak at 60, 90 and 120hz (although 80hz is the maximum in dbdrag ) Quote 10.x volts fo' life!
BigPimpin91 Posted June 9, 2009 Report Posted June 9, 2009 if my box is tuned to the lower hz..(30-35 or so) is it still ok to burp in a comp? or should i tune it to 70hz or higher to burp and leave the lower hz to music? 1st Question. Yes, you can burp no matter what your box is tuned to, only thing that changes is the peak frequnecy. 2nd Question. I believe you are trying to refer to swappable ports. Sometimes they work, others they don't. All about testing, but I doubt your vehicle peaks above 70hz. My current set-up peaks @ 33hz. Previous was @ 48hz. All depends on subs and box. Quote BigPimpin91's Banging Music
