basshead4life Posted June 12, 2009 Report Posted June 12, 2009 My dad gave me a 160 amp alternator off a boat. they just upped to a 200 and were gonna throw the 160 away there was nothing wrong with it when they took it off but they just wanted bigger. i just dont know how to make it work. its internally regulated. but theres 4 bolt on connections on the back. 1- GND: its obvious 2- BAT: also obvious 3- I: i think it means indicator 4- R: i have no clue heres some pics any help will be apprciated. side view rear view Team S.M.D. Maritime Car Audio- (2) 18" SSA ZCON D1 - American Bass 500.1 - 60 ft of 3/0 -480 Ah of battery - (2) stock alternators (70 +90) - Kenwood Excelon x-794, 4v preouts car audio is just a LOT more complicated than "this amp does this power" or "this sub will be this loud". its like 2 + 2 = banana. (if that confuses you then you get the point) lol
Soulman07 Posted June 12, 2009 Report Posted June 12, 2009 What kind of plug does it have on it? If it's internally regulated the the pins on the plug should provide power to all the internals and the only thing you would need is ground/battery connection I have 0 experience with boat alternators though so I don't think I'll help much. Aside from that external regulators have I (switched 12v) B- (Ground) A (Battery) S (Where stator meets rectifier) F (positive field on brush holder) 1993 Chevrolet SWB Pickup Viper 791XV Primer Stage 5/8 Static Drop Kinetik HC1800 Big 3 Knu Flex 0 Team Tex Flex
basshead4life Posted June 13, 2009 Author Report Posted June 13, 2009 the bolts on the back are the only way to hook wires up the only one that u cant see in the pic is the ground. Team S.M.D. Maritime Car Audio- (2) 18" SSA ZCON D1 - American Bass 500.1 - 60 ft of 3/0 -480 Ah of battery - (2) stock alternators (70 +90) - Kenwood Excelon x-794, 4v preouts car audio is just a LOT more complicated than "this amp does this power" or "this sub will be this loud". its like 2 + 2 = banana. (if that confuses you then you get the point) lol
