Alpine Cda-9887 Crossover Help
are you running it in 3way mode or not also are you considering doing the imprint to it elaborate a little more on what you need to know also what is your mid and high setup amp/speaker etc thanks i'll be glad to help
Car is 2010 Scion Tc
Currently in car
Deck- Sony XAV-60 in-dash mobile video system
Speakers- Rockford Punch 6.5in comps in the front and coax in the rear
Subs- 2 Gen 3 Rockford P3 12's dual 4 ohm
Amps- Rockford P1000-1bd and P400-4 Alpine Mrp-f300 is in for P400-4 which is out to service
Wiring- all rockford nuff said
Enclosure- Dual 12in custom box by SRQ
Battery- Optima Yellow top with big 3 done
Sound Damping- All Dynamat products 1-2 layers throughout with liner on top
Link to my build log- http://down4sound.co...=newpost&t=5275
Link to my youtube- http://www.youtube.c...ser/Jville140db
MECP Advanced CEA # 110531
BassBox 6 Pro for Box Building/Re audio box calculator
If you can hear the passenger it aint loud enough!!!!!!!
QUOTE (MickyMcD @ Sep 25 2009, 07:25 PM) "My system has 30 speaker terminals, that means shits wanging doggggg....."<!--QuoteEnd--></div>
yes it is in 3way mode. my mids are rockford fosgate t162c and my highs are 6x8 3way pioneers. im running them off the headunit so no amps.
ok any subs sorry should have asked that before
Currently in car
ok so you are running this in 3 way first switch it back so that runs like a regular deck otherwise your front channel will act like a mid then set you front cross over at about 80 hz with a 12 db roll off then set your back speakers at 50 hz with a 12 db roll off then turn off your crossover on your sub amp and set the sub at 63hz with a 12db rolloff and you should be set let me know how it sounds
Currently in car
it is user preference, what sounds good to you may sound like crap to someone else.. you cant run the deck active without amplification.. so set to normal then adjust according to your preferences.. you really arent using the deck to its potential till you get amps for tweets mids and subs. 2 channels dedicated to tweet 2 to mids and one mono for sub
07 mote carlo..
deh-p800prs hu-cdt gold 6.5's-cdt 6x9 2 ways-mcintosh mc431m(mids/highs)
bxi2608,2 10w7's in 4rth order(designed by pete k)ported into cabin via armrest cutout
dc power 260 amp alt-missing link module (15.4v)kicker 1/0 kit deka intimidator under hood
metered 141.0 @ 32hz windows down @ kick,termlab
I completely agree with you 100% but if he is going to run it the way he mentioned that should at the very least protect the drivers until he gets an amp. But yes you can't really appreciate this deck until you do a full setup.
ps get imprint lol
Currently in car
  • Who's Online   0 Members, 0 Anonymous, 1295 Guests (See full list)
