Bali Posted June 17, 2009 Report Posted June 17, 2009 Do you really NEED 2 grounds? I have no location on my engine block that i can fit my connector on and i don't see the point anyway?
B Slaps Posted June 17, 2009 Report Posted June 17, 2009 Do you really NEED 2 grounds? I have no location on my engine block that i can fit my connector on and i don't see the point anyway? iirc all vehicles come with 2. atleast my hoe and rex do. I Rock 4 Doors 4 More Whores! SMD SUPER SELLER my seller feedback http://www.stevemead...-mama-feedback/ more seller feedback http://www.stevemead...-slaps-yo-mama/
Bali Posted June 17, 2009 Author Report Posted June 17, 2009 iirc all vehicles come with 2. atleast my hoe and rex do. come with 2 what? i don't understand what you're saying
velcroslap Posted June 17, 2009 Report Posted June 17, 2009 two grounds. one from batt to frame, and one from batt to engine block. * Head Unit: Kenwood KDC-MP732 * iPod Interface: KCA-iP500 * Front Stage: Rockford Fosgate Power T1652-S * Front Stage Amp: Rockford Fosgate Punch P400-2 * Rear Stage: Alpine SPR-13C Type-R 5-1/4" * Amp: Rockford T10001bd * Subs: (2) 15" Rockford P3s * Front Battery: Optima RedTop * Back Battery: Kinetic Hc2400 * Wiring: Rockford 1/0 * Big 3: Rockford 1/0 * Enclosure: Idyllic
Bali Posted June 17, 2009 Author Report Posted June 17, 2009 two grounds. one from batt to frame, and one from batt to engine block. alright well, im using these huge screw connectors instead of ring terminals and there is seriously no place to put a ground on the engine so, iono : :shot:
Gibbs Posted June 17, 2009 Report Posted June 17, 2009 Well I just replace my ground at it was only 1 from batt to engine block (actually to the tranny but whatever lol). Another ground that came stock from factory on my car is alt to frame. Check out my build and the band Like We Always Do! Once you start you can never stop. Bass addiction is serious. And there is no 12 step program for it. Subs are like titties, They need to come in pairs because ones and threes are just wrong, and larger amounts will always draw a crowd, we all have our favorite sizes, but the bigger ones are more fun to watch move.
CaptainzPlanetz Posted June 17, 2009 Report Posted June 17, 2009 alright well, im using these huge screw connectors instead of ring terminals and there is seriously no place to put a ground on the engine so, iono : :shot: Just take one end of it and put a ring terminal, then take a bolt off the block connect the terminal then torque it back to specs, I know alos of people like to use tranny bolts to connect the ground, but depending on your car that may or may not be easy. ¿ǝɯɐƃ ǝɥʇ Trolls never learn............ All BS aside, If I see one more comment in here that is NOT about the pre-sale, I will start the vacations. And that includes the trolls feeding the trolls. YOU THE ONE THAT SOUND LIKE A OGER AND HUMPBACK/TROLLS? Add "SMDLIFER" on Xbox LIVE to play with other SMD members.
javy101 Posted June 18, 2009 Report Posted June 18, 2009 all i did is put a terminal on my wire than connected it to my starter bolt which alot of times is one of the most visible places
