I have a 1997 GMC C1500 with the 5.7 motor.
I recently pulled the gas tank to patch a hole. I reconnected the tank and all wires (double checked to make sure wires and hoses were reconnected properly). I go to start the truck and it would rotate but not start.
I pulled the filter and started the pump up and it was pushing gas through the system. I replaced the filter with a new filter. Engine would still not fire.
I pulled the ignition coil and brought it to get tested. It tested out fine and while I was at the auto parts store I picked up a distributor cap and rotor.
Got home and reassembled everything and it would still not fire.
Any ideas?
Make sure you check all of your fuses.
HU: Pioneer
Highs: 2X 4X6"s, 2X 3.5"s, 4X 5.25" comps, Q-Logic kicks, and a Sundown SAX-125.2
Subs: 4 Nightshade 15s and Strapped SAZ-3500Ds <---Sundown FTW good.gif
Electrical: dual DC Power 320s (ordered) and 2 D3400s up frt and 4 D2700s in the back
.ʇı ɥʇıʍ ʞɔnɟ ʇ,uɐɔ noʎ 'ʞɔıp ǝɹos ɐ ǝʞı1 sı uʍopunS
hmm wires didn't get messed up did they. none are split? and are you sure the pump is good? maybe weak and not pushing enough gas? just a a couple things i'm thinking of. ill ask around see what i can dig up for you
think i isolated the problem down to low fuel pressure. going to pull the pump and check the strainer tomorrow.
have you checked the pressure with a gauge?
with the key on you should see 60-66 psi, truck on at idle
should be in the high 50's and when you blip the throttle above 60 psi.
center console: lvl 4 12 1.75 cu ft tuned 37htz
alpine cda-9886
dc audio 120.4
infinity kappa 6.5" components
Some are pressurized even higher at idle.... I'd take it to a mechanic and have them to a pressure check on it. I have a 97 astro was the same, It would start with a shot of ether in the intake and run. Wouldn't start when you crank it though. Fuel pump wasn't putting out enough PSI to start or keep it running for long. If it was working before and not working now It may be something simple causing it. Make sure you are getting power to the fuel pump. An there should be a fuel pump fuse/relay somewhere in your vehicle
1993 Chevrolet SWB Pickup
Viper 791XV
Primer Stage
5/8 Static Drop
Kinetik HC1800
Big 3 Knu Flex 0
Team Tex Flex
might wanna check the ign mod in the bottom of the distributor. u can have it tested at oreillys or auto zone. cost 30 to 50 bucks. could be working but weak
Edited by t-money
2002 ford focus hatch
pioneer DEH-P8400bh
infinity kappa 6.5 components front and rear
XS Power D1200
Shuriken BT-100
audioque 120.4
2 15 inch audioque HDC3 D2
2 audioque 2200d
big 3
mechman 220a alt with external regulator
479-418-3056
  • Who's Online   2 Members, 0 Anonymous, 609 Guests (See full list)
