If it's pure burpy numbers you want then build for 66hz. If you peak at 33hz you'll also peak at 66hz.
Don't tune the box to your peak. Tune it a few hz below the peak, once you get it in the car the combined setup will peak a bit higher than the tuning.
You need a bigger box and more port. Try to get 10 cubes after displacement with 180-200 square inches of port if it's purely for burping. Or 6 6" aeroports across the back of the box.
thanks man im going to leave it a lone i was just hopeing to get a 150.xx maybe with the new alty when it gets here hope it will pick up 5tenths but i dont know im doing a 149.5 @28hz so im happy with it im just tired of plp doing a 150.00 @ 45 to 50 hz but i like the ground pounder thing thanks for all your help
