Guest Posted June 26, 2009 Report Posted June 26, 2009 (edited) I have my Toshiba Tecra 8100, and everytime i turn on the laptop, the screen displays a white blotch on the top right then an orgy of lines come up. i can attach an external monitor and it displays 100% fine. is the problem the LCD itself or the little Inverter? i need to fix this laptop for a job so any help will be fine about 3/4 way in the video i do key commands to shut off the monitor then turn it back on Edited June 26, 2009 by Krannyman92 Quote
BulletInjection Posted June 26, 2009 Report Posted June 26, 2009 bump?... only 1 bump a day. graphical chipset errors? lol The internal connection to the screen has a problem of some sort. That is waht I think if you can connect a secondary and the vga port display is fine. Quote My build: http://www.stevemeadedesigns.com/board/ind...8920&st=100 http://www.youtube.com/Bulletinjection
