ok, I have 2 kicker 12" solo x subs, and the kicker website says for best results in the lows and most power handling I should have each sub in a 6 cubic ft box, so I have my 2 12's in a 12 cubic ft box.
I am running both subs at 2ohms off of a kx2500.1. the amp is 2600wrms at 14.4. so lets say each sub is getting 1200-1300 wrms....
where i am not giving the subs what they recommend, should I make the box smaller due to the lack of power going to the subs??
subs are 2500wrms a piece...
their fine. i dont think the solo x's can handle anything over 2500rms daily iirc.
the smaller the box, the MORE power you will need to get the same output as a bigger box with less power.
here this is from the site and if you use this youll only be underpowering them by a couple hundred watts
3 ft3 (85.0L) + port displacement, Fb=40Hz
Port: 45 in2 (290cm2) area x 18.75” (47.6cm) long
Power Handling = 1400W Peak
Team S.M.D.
Maritime Car Audio- (2) 18" SSA ZCON D1
- American Bass 500.1
- 60 ft of 3/0
-480 Ah of battery
- (2) stock alternators (70 +90)
- Kenwood Excelon x-794, 4v preouts
car audio is just a LOT more complicated than "this amp does this power" or "this sub will be this loud". its like 2 + 2 = banana. (if that confuses you then you get the point) lol
now, I was thinking about doing that....but would 1 sub at 1ohm with 2600wrms be louder(higher spl) than 2 subs at 2ohm with 1200-1300 each...???...
it would be pretty much the same loudness wise. since your halfing the cone area but doubling the power.
can a solo x even take 2500rms daily?
i dont think. sumone on here said once that theyll blow up if more than 2000 is used on daily setup
Team S.M.D.
- 60 ft of 3/0
-480 Ah of battery
well they are rated for 2500 wrms, but I'm not sure about daily. I had 1 in a 6 cubic ft box and ran it at 1 ohm for about a month, no probs........
N.S. eh? where u at?
thats what i heard also.
