need help setting amp
basshead4life
ive got a kenwood kac x1r at a 1 ohm load and i was wondering what i should set for the upper and lower cutoffs right now its 15hz and 200 hz and when i play C&S songs my subs get a little smelly. and my box is tuned at 28hz if it helps any.
Team S.M.D.
Maritime Car Audio- (2) 18" SSA ZCON D1
- American Bass 500.1
- 60 ft of 3/0
-480 Ah of battery
- (2) stock alternators (70 +90)
- Kenwood Excelon x-794, 4v preouts
car audio is just a LOT more complicated than "this amp does this power" or "this sub will be this loud". its like 2 + 2 = banana. (if that confuses you then you get the point) lol
your clipping the amp. first off, set the Subsonic Filter to about 28hz. and set the LPF to 80.
yea i thought htat might be it vut i wasnt sure. i had it set with a dmm in my parents car but that was at 13.5 v and now in my car its at 14.4. but i just got a new car and i want to set it right this time.
Team S.M.D.
- 60 ft of 3/0
-480 Ah of battery
the more voltage your car can produce, the more output for the amp. set the gains for your amp by following that giant picture.
that amp is super inefficient at 1 ohm. it does 1200rms at 2 ohms, then like 1000rms at 1 ohm. so says sonicelectronix
that doesnt make it inefficient. it just means that it cant handle the amps it takes to run 2400watts at 1 ohm. its the same reason that most amps wont run 0.5 ohms. the circuitry will heat up too fast. they will all run 0.5 ohms but only be able to safely push half of the 1 ohm ratings. for example: my amp will only push 500 watts safely at 0.5 ohm or 250 watts at .25 ohm.
Team S.M.D.
- 60 ft of 3/0
-480 Ah of battery
  • Who's Online   0 Members, 0 Anonymous, 620 Guests (See full list)
