DC Sound Lab
ok i saving to get 2 dc lvl4 xl 15's and i got box designed and everything but want to double check something is 3.36 cubes per sub enough for these at 2k rms per sub box tuned to 32.82hz? the cubes per sub is with out the sub displacment not sure if i will mount them normal or inverted. anyone have some insight on this?
is this a ported box single chamber box?
2010 IDBL Rookie 1 North American Champion
2009 IDBL Rookie 1 Fl State Champion
2009 EBB Fly Weight 3rd Place Fl State Finals
2006 Silver Grand Prix GXP :Diablo Audio Hellfire 1000.1, JL Audio 300/4, One 13W7, ZR650, VR690, JL Cleansweep setup.
Team Pure Pressure
true it should be.....is the box ported? if so did you subtract the port displacement? just checking?
i would say mount them normal....but then I have never inverted the mounting.
Edited by shainemcconnell
Team Pure Pressure
ya the cubes per chamber is after port has been subtracted :)
i was actually working a new box today for some lvl4's with lvl 5 VC's and that box is a little over 3 cubes with a 4 inch Kerfed port. ..
so yeah you should be pretty good with the 3.36...but if you were to compete with them I might suggest a little larger, only if you wanted to compete though
Team Pure Pressure
yeah..you should be good then, for sure. be sure to route the edges of the port when you are finished...it will help reduce the chance for port noise.
Team Pure Pressure
  • Who's Online   0 Members, 0 Anonymous, 7224 Guests (See full list)
