buxton Posted July 10, 2009 Report Share Posted July 10, 2009 2000 chevy ext cab knukonceptz amp kit 2 kicker cvr 12's at 2 ohms hifonics brutus 1210d sony xpld head older model not sure on exact the subs are scratching and have something similar to a static sound i played with the rca in the back of the head unit and they started soundin like brand new and after they get turned up real loud they will sound fine for about 5 min and if you turn the head unit off and back on it will sound fine they are in a vented 12 box jus for some extra info.....i personally think its the head unit but i would like a second opinion 2000 toyota tacoma ext. cab JVC AH-59 head unit knukonceptz 4ga kolossus Amp kit hifonics brutus 1200D 2 Kicker CVR 12 prefab vented enclosure Link to comment Share on other sites More sharing options...
Crump Posted July 10, 2009 Report Share Posted July 10, 2009 2000 chevy ext cabknukonceptz amp kit 2 kicker cvr 12's at 2 ohms hifonics brutus 1210d sony xpld head older model not sure on exact the subs are scratching and have something similar to a static sound i played with the rca in the back of the head unit and they started soundin like brand new and after they get turned up real loud they will sound fine for about 5 min and if you turn the head unit off and back on it will sound fine they are in a vented 12 box jus for some extra info.....i personally think its the head unit but i would like a second opinion ground the rca's thats usually the problem. http://www.icixsound.com/vb/showthread.php...age=1&pp=10 Team gg Team doa Installs I have doneMy 2010 Rebuild 144 db so far....2 DC xl 10s Firing into cabin on a RF 25002 12" AQ HD's powered by a Saz 2k + Lots o Mids+Highs Link to comment Share on other sites More sharing options...
Rogers Posted July 11, 2009 Report Share Posted July 11, 2009 yep sounds like its time for a new set of rca's or the output on your deck is shorting out.... http://www.stevemeadedesigns.com/board/topic/79921-rogers-700-dream-car-update-page-17-a-wall/?p=2335774 93 Saturn SC2My system4 SA-15's Walled 2 Cerwin-Vega S2000's 3 Kinetik Hc2000's Dual 200amp alts. you guys done with the peepee touching contest or do I need to end it? Link to comment Share on other sites More sharing options...
