Give me a schematic of what all you have. List it out from source back to the speakers.
kenwood ddx719 plugged into factory harness
rca running to clarion eq (grounded at seat mount bolt) (powered from cigaret lighter wires)
rca from eq to amps in trunk
current set-up
kenwood ddx 712
clarion eq
focal 165 k2p front
focal 165v2 rear
2 re audio sexxx 12
us amps md3d
us amps md42
1 optima yellow top (rear)
1 xs power 5100r (front)
big 3 and 1 run 1/0 stinger wire
my build
my rebuild
Posted (edited)
i had a bad whine up until last night... i took off my capacitor... no whine!!! so just in case u have one, i say fuk a capacitor... lol thank u...and i have a question...how come u didnt just run ur eq off of ur power ant. wire from the radio???
Edited by 8000watts
damn i didnt even think of that
i dont have a capacitor just a battery in the back i know its grounded good
current set-up
kenwood ddx 712
clarion eq
focal 165 k2p front
focal 165v2 rear
2 re audio sexxx 12
us amps md3d
us amps md42
my build
my rebuild
i also noticed today when i turn my headlights to on i get feedback through the speakers also i could the wiring harness be bad? do those even go bad? im just gonna rip everything out and put it back in im trying to get it figured out before i put my RE SExxx subs in next week im fuckin stumped.
current set-up
kenwood ddx 712
clarion eq
focal 165 k2p front
focal 165v2 rear
2 re audio sexxx 12
us amps md3d
us amps md42
my build
my rebuild
which type of groundloop isolater do i need where do i order it
current set-up
kenwood ddx 712
clarion eq
focal 165 k2p front
focal 165v2 rear
2 re audio sexxx 12
us amps md3d
us amps md42
my build
my rebuild
Noise when you turn on headlights and certain things most definitely sounds like a bad ground. Your seat belt bolt is one of the shittiest places to ground things. You'd be better off grounding your eq off of the tip of your wang than your seat belt bolt. Move that ground to a better location. Next, find a better location for the power of the equalizer. Where is your head unit grounded? Where are your amps grounded? Do you have a 2nd battery?
2 - Audiopipe AP30001Ds
1 - Lanzar Opti Scion 600.4
4 - Lanzar Optidrive 1232D's
1 - Lanzar Opti 5.1
1 - Lanzar Opti 6.1
1 - Lanzar Opti 6C midbass
1 - Alphasonic PCT6551
1 - Lanzar VX830
1 - JBL 22 band EQ
1 - Lanzar SDBT75NU
1 - AudioControl Epic160
His problem looks to be bad grounds, which should be fixed first.
1 - Lanzar Opti 5.1
1 - Lanzar Opti 6.1
1 - Lanzar VX830
1 - JBL 22 band EQ
1 - Lanzar SDBT75NU
my headunit is grounded of the wiring harness wherever te factory harness is grounded
what if i power the eq off of the power antenna output of the headunit or just splice it in to the power of the wiring harness
im going to move the ground back where the he unit harness is
my amps are grounded to the battery less than 3 feet
the second battery is grounded to the frame by the tailight and to a bolt that secures the factory tire jack housing
current set-up
kenwood ddx 712
clarion eq
focal 165 k2p front
focal 165v2 rear
2 re audio sexxx 12
us amps md3d
us amps md42
my build
my rebuild
  • Who's Online   0 Members, 0 Anonymous, 895 Guests (See full list)
