Absolutely. Get a multimeter, set it to turn caps lock off, then turn it to ohms. You'll want less than .5 ohms from point to point if you can.
First, run a dedicated ground to the rear battery to feed your head unit.
Does your EQ have constant, remote and ground, or just ignition and ground?
The factory tire jack housing is piss poor too. You need clean chassis, not things that are just tack welded onto the body.
2 - Audiopipe AP30001Ds
1 - Lanzar Opti Scion 600.4
4 - Lanzar Optidrive 1232D's
1 - Lanzar Opti 5.1
1 - Lanzar Opti 6.1
1 - Lanzar Opti 6C midbass
1 - Alphasonic PCT6551
1 - Lanzar VX830
1 - JBL 22 band EQ
1 - Lanzar SDBT75NU
1 - AudioControl Epic160
constant remote and ground for the eq
the frame by the tail light i scraped down to bare metal i have another spot behind the battery i can use thats frame
im going to run a ground from the hu ground all the way back to my battery
is it okay to use the power antennae of the hu to power the eq?
thanks for the help
current set-up
kenwood ddx 712
clarion eq
focal 165 k2p front
focal 165v2 rear
2 re audio sexxx 12
us amps md3d
us amps md42
1 optima yellow top (rear)
1 xs power 5100r (front)
big 3 and 1 run 1/0 stinger wire
my build
my rebuild
this is the eq that i havemy eq
Edited by ARMYSGT_D
current set-up
kenwood ddx 712
clarion eq
focal 165 k2p front
focal 165v2 rear
2 re audio sexxx 12
us amps md3d
us amps md42
my build
my rebuild
my headunit is grounded of the wiring harness wherever te factory harness is grounded
what if i power the eq off of the power antenna output of the headunit or just splice it in to the power of the wiring harness
im going to move the ground back where the he unit harness is
my amps are grounded to the battery less than 3 feet
the second battery is grounded to the frame by the tailight and to a bolt that secures the factory tire jack housing
did u sand and make that ground urself or was it jsut a hole that was already there?? sanding helps u get ALL the ground...wat i did wit my eq was basically run that straight to my radio...power to the radio's power, remote to the power ant., and ground to the radios ground...dont kno how others feel about that but it works perfectly fine to me! u should try that and while ur shit is still ripped out of the dash, (so u dont have to take it bak out if it didnt work) turn it on and check it out...
i would try that but i have ground noise with just the h/u maybe its the car or the stock ground i should try changing the stock ground
current set-up
kenwood ddx 712
clarion eq
focal 165 k2p front
focal 165v2 rear
2 re audio sexxx 12
us amps md3d
us amps md42
my build
my rebuild
OH!! well shit. yea u should try changing the stock ground...or at least check ur connections if ur gettin it through the h/u alone...thats weird...
maybe something came loose back there also there is a shit tone of wires bunched together all the factory stuff and there is only qbout an inch of clearence between the fire wall could that have something to do with it
current set-up
kenwood ddx 712
clarion eq
focal 165 k2p front
focal 165v2 rear
2 re audio sexxx 12
us amps md3d
us amps md42
my build
my rebuild
Start with the stock ground for the radio. You're running an aftermarket setup, so ground the head unit, the eq, and the amp to one central clean spot. VERY clean setup for the eq by the way. Another trick, since you're running some wires, once you get them to the back, twist them around to make it a little neater.
1 - Lanzar Opti 5.1
1 - Lanzar Opti 6.1
1 - Lanzar VX830
1 - JBL 22 band EQ
1 - Lanzar SDBT75NU
i did all the stuff you guys said and still couldnt get rid of the noise so i took it to the shop and they said they have that problem sometime when the change they head units and cant get rid of it without a filter so i am just going to get a filter
can you guys tell me which one to get
current set-up
kenwood ddx 712
clarion eq
focal 165 k2p front
focal 165v2 rear
2 re audio sexxx 12
us amps md3d
us amps md42
my build
my rebuild
  • Who's Online   0 Members, 0 Anonymous, 882 Guests (See full list)
