Kicker 1000.1 Help
puyallupn8ive
I just bought 1 of the newer Memphis Mojo 12 2ohm, and I have a Kicker 1000.1 What can I do with wiring this sub to this amp? Or should I just get another amp? I don't know what to do. Any help would be great, Thanks
98 Toyota Camry
Eclipse AVN-6600
AudioControl 3.1
AudioControl Epicenter
US Amps AX2000
US Amps MD-43
1 set Alpine type X components
1 set RF Power components
1 12" RE Audio XXX
220 Amp Iraggi Alt.
Red Top (Front)
Kinetic HC-600 (Back)
Second Skin Damplifier Pro
Thats a great amp but only puts out 1000rms and some at 2 ohms, you have a choice of either wiring it at 4 ohms or 1 ohm(which I wouldnt recommend for that particular amp) you could run at 4 ohms and probably put about 600-650rms to it until you can get an amp that does its power at 1 ohm.
¿ǝɯɐƃ ǝɥʇ
  • 2 months later...
you really need to put more than 500 per sub on the mojo, they love extra power
Ride-1996 Toyota 4Runner Limited Edition
Head Unit-Alpine iXA-W404
Front Speakers-Memphis M-Class 6 1/2 Oversize
Subs-2 DC Lvl 4xl 15's
Amps-2 Sundown 3500d's
Batteries-2 Batcap 2000's
240 amp Iraggi Alternator
Wiring-Memphis 0 Gauge Kit
Extra-Compustar Alarm/Remote Start/Keyless Entry
If its your memphis mojo 12 D2 is built anything like the old ones you should have no problem running 2000 watts on it.
So if it is that particular type Mojo then if it was me I would purchase a 2nd Kicker 1000.1 that is identical to the one you have already and use 1 amp per coil or sell what you have and find a good quality 1500 or 2000 watt 1 ohm stable amp.
As far as the newest Mojo's I don't know anything about them so I don't know if they can handle big power like the old ones.
Isobaric - Refers to the practice of coupling two drivers together to make them act as one.
"Giving up doesn't always mean you are weak; sometimes it means that you are strong enough to let go."
Insanity: doing the same thing over and over again and expecting different results.
The Destruction of a person builds character.
  • Who's Online   0 Members, 0 Anonymous, 586 Guests (See full list)
