well you only need 4cuft after displacements for the sr 10's. also your putting 1000rms on 4 subs with more cone area then the the two 15's.
2000 gmc yukon
4 sundown Zv3 15's
4 dd m2a's
kenwood kdc-x994
2 batcap 4000's 1 batcap 2000
dual alts.
154@37hz and climbing
http://www.cardomain.com/ride/3231683
http://www.myspace.com/torque150
4 10's is near double the cone area of 1 15,
i vote 4 10's :good:
head unit - Panasonic MXE CQ-C7403U
amp - Cerwin-Vega EXL 1200D
subs - (x2) Cerwin Vega V-MAX 15.4
box - 5.8 ^3 at 32hz
spkrs- Phoenix Gold Rsd Comps
have you contemplated running dd subs? you can get the 500 series for close to that. plus you would have a warranty unlike buying from ebay.
2000 gmc yukon
4 sundown Zv3 15's
4 dd m2a's
kenwood kdc-x994
dual alts.
Link please? I'm new to this sub game as I've only always been exposed to JL, RF, Alpine, etc. stuff.
Checked my trunk. I have no idea how I would fit four 10's in it without using the whole trunk. Anyone build boxes and could help me out with boxes for four or three 10's in a vented box? I would love to go big right now but I really can't so I'm thinking about just getting three or four of these Pioneer Champion Series 10's. If no one can help, I have a prefab bow for three 10's I can squeeze into my car, then again, cone area is just a little bit more than two 12's in which I might not even upgrade. Car is an 01 impala.
http://www.dealercostcaraudio.com/ts-w1007d2.aspx
Specs
Size 10"
Woofer Cone Material Composite IMPP Cone using Interlaced Aramid Fiber
Woofer Cone Design Cone Reinforcement Arcs
Surround Wide Roll, Three-Layer Fiber Woven Radial
Voice Coil 4-Layer, Long Voice Coil
Voice Coil Wire Copper
Voice Coil Bobbin Phenol Resin Coated Glass Cloth
Damper (Spider) Aramid Fiber
Damper Ring Yes
Top Plate Standard
Projected Pole Yoke with Vented Pole Yes
Magnet Construction Double Mass High-Power (74oz)
Basket Design Stamped Basket with Magnet Cover
Gasket Molded
Wire Terminals Integrated Single-Sided Silver Compression Terminals
Specifications
Watts MAX. Music Power 1000 Watts
Watts Nominal Power Handling 350 Watts
Frequency Response 18 Hz to 600 Hz
Sensitivity 87dB
Ohm Rating D2 (2 ohm) D4 (4 ohm)
Recommended Enclosure 0.65 ~ 1.25 Cubic Feet
Dimensions 277 mm x 162 mm
Mounting Depth 143 mm
I can only afford alittl emore than $200 for now!
Edited by k3n12ock
