uluahunta808 Posted July 18, 2009 Report Posted July 18, 2009 i got a few questions about covering a box what kind of carpet or material do u use to cover ur box in? is contact cement a strong bond for applying carpet? if i do spray it what is a good paint to spray it with that is strong and wont scuff or srcatch? thanks guy Aloha.
Rogers Posted July 18, 2009 Report Posted July 18, 2009 i use felt... you can get it from your local fabric store... and i also use general puropse spray adhesive from walmart...its normally located near the caulk section... you may need 2 or 3 cans depending on the size of the enclosure....just take your time with the carpeting.... http://www.stevemeadedesigns.com/board/topic/79921-rogers-700-dream-car-update-page-17-a-wall/?p=2335774 93 Saturn SC2My system4 SA-15's Walled 2 Cerwin-Vega S2000's 3 Kinetik Hc2000's Dual 200amp alts. you guys done with the peepee touching contest or do I need to end it?
uluahunta808 Posted July 18, 2009 Author Report Posted July 18, 2009 well my first box i carpeted i used automotive carpet and it was thick. but that came out nice. and just yesterday i carpeted my other box with felt from wall mart and the edges look like shit because when i stretched it and cut it, then it shrunk back to size causing my edges to show wood
deaf_wish Posted July 19, 2009 Report Posted July 19, 2009 use unbacked carpet it streches real nice, and contact cement is great. i painted some on one time because i don't have a air compressor and it worked fine, just make sure you let it get tacky before you start wraping or it will soak thur the carpet. My build. http://www.stevemeadedesigns.com/board/topic/74265-project-clean-update-on-doors/ My other build. http://www.stevemeadedesigns.com/board/topic/100534-two-c3s-and-a-mojo2500-under-the-seat/
