SUDDEN HUM FROM MONOBLOCK AMP ?
hello i recently did my first small sound show with my truck : 04 armada with the following setup : jvc detachable 7" dvd player , audiopipe 8v line driver , 2 fi audio 18"s fully loaded dual 2ohms ea in a custom 10 cube ported box facing up port on rear , visonik 4000w amp with a 400a inline fuse for subs , custom doorpanels with 4 eminence pro series 10" midbass powered by a rockford 600w 2 ch amp , 6 x 8" clestion mids powered by a rockford 800a2 2ch amp , 6 x lanzar opti tweets on doors and dash powerede by an old school rockford punch 250 dsm amp , 2 kinetic 3800's batts , 250 a nations alt , 1 odd wire , 300a fuse underhood with a optima yellowtop , stinger 200a isolator , my problem is after the sound show were it played most of the day with a few breaks in between to cool down in hot sun , it developerd a hum when on idle from sub amp , but goes away when you shut off engine and when u rev past 1k rpm like at 2k or 3k rpm it wont do it , so did i develop a groung loop prob? or maybe a pinched rca wire from from front control unit to sub amp? i was thinking of running a jumper from front unit to sub amp and see if it goes away? any suggestions?.................ps nthe truck was a blast at show ! it really attracted a lot of attention with its ground pounding bass and super clear mids !!! not bad for a first show , things can only get better my friends. steve please help !!!
Man Iv got the same problem all of a sudden. Mine didnt start until I got my amps strapped and everything finished, & now with the HU at 0 I can hear the subs, sounds lie static or interference But I have no idea where from.
Current System:
Pioneer 6900 HU
Front Stage: (for now)
Soundstream tarantula 5.25 in the doors
Soundstream tarantula 4x6 in the dash
Kenwood 400.4 for mids & highs
Bass:
4 Soundstream RW-12's
2 Power Acoustik Stax 4000/1D's
single chamber box, 2.65 cubes.
Currently under the knife being bagged
Rebuilding err'thang
yeah man im waiting to get my truck back from dealer to continue checking my rca connection and possible loose ground ect ill keep you posted i have not really completed my big three yet sofar i have replaced the ground from battery to chassis with a 0ga and ran 0ga from front batt to rear i still have to add a 0ga from alt pos to batt pos just alongside the factory one and also add one alongside the ground strap for the engine that should do it...
if you are picking up engine noise then yes it is a ground problem. wrap some 18 gauge speaker wire around your rcas where they connect at the headunit and then ground those wires somewhere.
I just went out & dont notice it now. it might be an off/on problem for me. I hate those kind of problems :(
Current System:
Pioneer 6900 HU
Bass:
  • Who's Online   0 Members, 0 Anonymous, 1033 Guests (See full list)
