Like new AudioControl Overdrive Line Driver $80 Shipped (lower 48)
Specs:
line driver provides up to 24 dB of gain (9 volt RMS maximum)
gray steel chassis with gold-plated RCA jacks
top-mounted controls for easy adjustment
2-channel preamp inputs and outputs
balanced inputs and outputs eliminate noise
light indicates 2-, 5-, or 7.5 volt output
frequency response: 10 to 100,000 Hz
signal-to-noise ratio: 110 dB at full output
maximum output level: 9.5 volts RMS (13 volts peak)
fuse rating: 1 amp
size: 5"H x 4-1/4"W x 1-1/4"D
Nobody makes me bleed my own blood, NOBODY!!!
This topic is now closed to further replies.
