Sorry im an idiot but this is what it says Dual 4 ohm 3” Hi-temp Aluminum voice coil wound on black anodized voice coil former
Level 3
The level 3 sub is the ultimate daily driver sub.
It puts out the low lows and lots of output designed for sealed or ported enclosures.
The Level 3 sub is a triple stacked FEA optimized motor wrapped in a magnet boot
with a chrome top plate and T yoke, the deep gap offers more X-max for 22.5mm.
This sub also comes with a upgraded progressive spider, cone, surround, 3" voice coil, cast basket, push terminals, and upgraded lead wire.
We give the Level 3 a power rating of 600w RMS/1200w peak and is probably our #1 seller.
Key Features
• Extremely rigid non-pressed paper cone assembly
• Multilayered polymer foam surround
• Polypropylene dust cover with embossed DC logo
• 8” OD semi cup progressive roll spider
• Extra heavy duty interweaved tinsel lead wire
• Cast aluminum black frame
• FEA analyzed and optimized motor assembly – Fully CNC machined
• Rubber mounting gasket
• Chrome spring loaded push terminals
• Dual 4 ohm 3” Hi-temp Aluminum voice coil wound on black anodized voice coil former
• Rubber magnet cover
Edited by xNOxSK1LLZx
