ok so i have a bamf 2000 amp hooked up to a audioque 15 sd2.5 and the first 3 days i had it hooked up it worked fine but now once you go so loud it will just cut out the amp doesnt go into protection either can anyone help me with this please
im pretty sure it has to do with the black and white plugins you put from the radio to the amp
plz can someone help me thanks.
X2. Check grounds on HU and Amp. Sand the paint off if possible.
Also check your voltage.
grounds are good...say ill have the vol at 20 and bass knob half way it will work then oncce i put the vol up to 21 itll start to cut out....when i go back to the amp you can also hear a little click then it will start to work again untill it cuts out again
idk if this will help but if i turn down the bass on my hu i can turn up with vol a little bit more but once i start to turn it back up itll start cuttin out agin
  • Who's Online   1 Member, 1 Anonymous, 586 Guests (See full list)
