thegreat22 Posted July 30, 2009 Report Posted July 30, 2009 Someone told that it is best to go for a 2 ohm load rather than 1 ohm in a daily driver. Is this true
enemyofsilence Posted July 30, 2009 Report Posted July 30, 2009 depends on the subs, amps, and your electrical to back it up. if your amp can perform the 1 ohm load and you have the electrical to back it up, then this is best (of course this also depends on your subs as well). if you have an amp that cant handle the 1ohm load, then 2 ohm would be the better choice. and its a little eaiser on your electrical Team Bass-Hz
thegreat22 Posted July 30, 2009 Author Report Posted July 30, 2009 I was looking at the merlin md 3d and it is safe at 1 ohm or the kicker 2500. Plan on getting a mechman alt
