etaks_crew Posted August 1, 2009 Report Posted August 1, 2009 Well after about three months of having my system in the stock battery took a shit. So I called my dad up and he got a replacement non-spillable gel battery for under my hood. He also got me another battery so I could add a second battery again( Same brand but bigger ). Anyways so I install the second battery and clean up my big three and I was fine for about a week when my amp shut off while I was bumping. So I check my connections and the power cord was a little lose up front so I tightened it and replaced the fuses it turns on if I turn it up for about 10 seconds all the fuses pop. I put y buddy's JBL amp in to see if it was the amp and smoked his fuses as well. Any help will be much appreciated.
Blazerbass Posted August 1, 2009 Report Posted August 1, 2009 did you ground the second battery? http://www.secondskinaudio.com/
Mtgrooves Posted August 1, 2009 Report Posted August 1, 2009 Put a meter on your subs and check your ohm load also check each coil you might have a a bad sub The Shoe Maker without shoes!
etaks_crew Posted August 1, 2009 Author Report Posted August 1, 2009 Yes I grounded the second battery and I guess ill have to check the subs.
