Ugh, so today I replaced the ground wire on my amp, I turn on some BME click and my sub starts making this loud "farting" noise.
With my volume on 16 and below it doesnt make this noise, but on 17 and higher it does it.
I took the sub out of the box, everything looks fine on it, voice coil isnt rubbing, its still in good shape. The sub is a 12 inch blaupunkt thats like 7 years old.
any ideas?
I wasnt pushing it hard when it started making the noise too.
EDIT: I guess I fail at embeding so Im putting up the link
Edited by BLuejoules
7e770874-fae3-49d5-ad82-4cabf106fead_zps d3abdb88-50bf-42d8-9628-e257559ec11d_zps
IG: devinthydude
It sounds like some part of the box might be rattling. Check all of the surfaces on the box.
My comp setup (Not bad for what it is):
HP Compaq Presario V6120US laptop with:
15.4" widescreen
AMD Turion 64 X2 1.6GHz processor
2x1GB stick DDR2 SDRAM (667 Mhz)
Seagate Momentus 500GB SATA HDD
128MB shared video memory
Windows 7 Home Premium 64 bit
12 cell Lithium Ion battery (actual battery usage time: 6 hours)
What it does:
On a USB 2.0 Wireless card
It definitely sounds like a part of the box is rattling. Place both subs in the box and turn the volume to just under clipping and firmly press on each surface of the box until it quits. Make sure to only do one surface at a time. If it doesn't quit, then I don't know what it could be.
15.4" widescreen
What it does:
is there any way u can video tape this somehow?
what do u mean by farting? and what kinda amp u runnin to it n what wattage sub? n what ohm load? all of those ?'s will affect the said farting racket
here's a link to my system 99 toyota tacoma , 2 mtx 8000 1504's in a sealed downfire , 1000w memphis amp
here's a link to my other system my 90 geo prizm test car
heres a thread i got of new songs u can dl that are legal = Some Good Bangage/you Can Dl These Free And Legit
My bad, I though you had two. You'll likely have to get a video for us.
15.4" widescreen
What it does:
Yeah Ill make a video tomorrow, its like a constant farting noise, kinda hard to explain.
Its a 400~ watt JVC amp at 4 ohms and the sub is SVC 4 ohm and is 400 watts rms
IG: devinthydude
Sounds like to me the coil is smacking the back plate!
95 Civic Coupe
Pioneer AVH-P7600DVD
Kinetik HC-1200 In Front
Kinetik HC-2000 In Rear
Memphis 16-MCA3004
2 X Memphis 16-MCD1000 With Maxxsonics MLX-100
2 X DC LVL 4 XL 12's
Pioneer Premier TS-C720PRS In Door's
Kenwood KFC-6982ie In Rear Deck
All Memphis Wire/Rca's and misc.
  • Who's Online   0 Members, 0 Anonymous, 8718 Guests (See full list)
