odd noise *vid*
Ugh, so today I replaced the ground wire on my amp, I turn on some BME click and my sub starts making this loud "farting" noise.
With my volume on 16 and below it doesnt make this noise, but on 17 and higher it does it.
I took the sub out of the box, everything looks fine on it, voice coil isnt rubbing, its still in good shape. The sub is a 12 inch blaupunkt thats like 7 years old.
any ideas?
I wasnt pushing it hard when it started making the noise too.
EDIT: I guess I fail at embeding so Im putting up the link
Edited by BLuejoules
7e770874-fae3-49d5-ad82-4cabf106fead_zps d3abdb88-50bf-42d8-9628-e257559ec11d_zps
IG: devinthydude
It sounds like some part of the box might be rattling. Check all of the surfaces on the box.
15.4" widescreen
128MB shared video memory
Windows 7 Home Premium 64 bit
What it does:
On a USB 2.0 Wireless card
It definitely sounds like a part of the box is rattling. Place both subs in the box and turn the volume to just under clipping and firmly press on each surface of the box until it quits. Make sure to only do one surface at a time. If it doesn't quit, then I don't know what it could be.
15.4" widescreen
What it does:
is there any way u can video tape this somehow?
what do u mean by farting? and what kinda amp u runnin to it n what wattage sub? n what ohm load? all of those ?'s will affect the said farting racket
My bad, I though you had two. You'll likely have to get a video for us.
15.4" widescreen
What it does:
Sounds like to me the coil is smacking the back plate!
95 Civic Coupe
Pioneer AVH-P7600DVD
Kinetik HC-1200 In Front
Kinetik HC-2000 In Rear
Memphis 16-MCA3004
2 X Memphis 16-MCD1000 With Maxxsonics MLX-100
2 X DC LVL 4 XL 12's
Pioneer Premier TS-C720PRS In Door's
Kenwood KFC-6982ie In Rear Deck
All Memphis Wire/Rca's and misc.
  • Who's Online   1 Member, 0 Anonymous, 1838 Guests (See full list)
