Well i just got my 2 12" Alpine Type R's yesterday and they work fine but im having some problems with other things. every so often the protect light on my amp comes on and shuts the subs off....the wiring and everything is fine as much as i know and i dont know why this might be happening but its getting annoying. if i shut the car off and take the fuse out of the amp and put it back in it works fine for a while then shuts back off. can anyone think of why this is happening and how i might fix it?
yea i justput the subs in te box an i the new subs came with jumpers...maybe i wired that wrong?...i put the pos with pos and neg with neg then connected the neg wire from the box terminall to one of the neg on the sub then same with pos ad i did that on both subs...so u think i did that wrong?
ok, what you did wrong was that you wired the subs to 1 ohm.
search on this site for woofer wiring diagrams and youll see a diagram that shows you how to connect your woofers to 4 ohm.
If you still struglle, come call me
then im rambo bitch
