line drive/bass booster?
That rockford one seems to be a good deal, your deck has 4 volts but by the time it reaches the amp its not 4 volts.
yea i thought it was good, then i checked today what my voltage was at my amp, max volume is 35, i listen to it max 24 and at 25 it was not even 2volts, at 28 it was 2.8 volts. so i think i need some boost.
but what about when i add a 4ch and want that on a line driver also? that rockford one is only for 1 set of rca's
99 s10 4.3L
Big 3
220amp alt
Odyssey 1500
Odyssey 2150
Northstar NSB 75
Sundown Audio 3500D
Sundown Audio 125.2
3 Sundown Audio SA-12's
Alpine H/U
RF Power Comp set 6.5"
RF 3 sixty line driver
5.25 cubes @ 31hz
what will the rockford 3 sixty.1 voltage wise do at the end of the rca's a true 5volts, or will it drop some by the time it reaches the amp? i want to get a true 4-5 volts at the amp. either that or the audiocontrol matrix.
99 s10 4.3L
Big 3
220amp alt
Odyssey 1500
Odyssey 2150
Northstar NSB 75
Sundown Audio 3500D
Sundown Audio 125.2
Alpine H/U
5.25 cubes @ 31hz
Guest DC Power Kyle
I have a AC Matrix to the 3sixty. This way i can turn down the HU volume at my deck to 24 out of 35 and boost the matrix to 5 volts to the 3 sixty to turn down the 3sixty's input output levels to get a cleaner signal. Personally... I love it this way... maybe it's overkill but it sounds a hell of a lot better versus before.
If you're going to get the 3sxity.... get the .2
I can get a pretty good deal on them if you're interested PM me.
well i was orig. going to get the .2, but i really dont need all those big features of the .2... or is it that much more beneficial? i dont have a high end speaker system (mids highs) so i was more of less just looking for some boost of the signal. so would the .1 be better for me? it sure is a lot better price wise. lol
99 s10 4.3L
Big 3
220amp alt
Odyssey 1500
Odyssey 2150
Northstar NSB 75
Sundown Audio 3500D
Sundown Audio 125.2
Alpine H/U
5.25 cubes @ 31hz
RF makes a line driver check that out, it could be what you need.
98 Toyota Camry
Eclipse AVN-6600
AudioControl 3.1
AudioControl Epicenter
US Amps AX2000
US Amps MD-43
1 set Alpine type X components
1 set RF Power components
1 12" RE Audio XXX
220 Amp Iraggi Alt.
Red Top (Front)
Kinetic HC-600 (Back)
Second Skin Damplifier Pro
yea i posted that a few posts up, but thats only for a single amp, im looking to run a line driver for a 4ch amp and a sub amp.
99 s10 4.3L
Big 3
220amp alt
Odyssey 1500
Odyssey 2150
Northstar NSB 75
Sundown Audio 3500D
Sundown Audio 125.2
Alpine H/U
5.25 cubes @ 31hz
you wont need a line driver for your 4 channel Ive got one of the memphis line drivers even with an eclipse 5 volt deck the gain on the line driver is almost maxed out . after I added the line driver it sounds better and seems to be louder than before
if i was to get the 3 sixty, where does it get mounted, as it sends a 5volt signal out, should it be put any where, or close to the deck, or closer to the amps to get the most volts out of the rca's?
99 s10 4.3L
Big 3
220amp alt
Odyssey 1500
Odyssey 2150
Northstar NSB 75
Sundown Audio 3500D
Sundown Audio 125.2
Alpine H/U
5.25 cubes @ 31hz
  • Who's Online   0 Members, 0 Anonymous, 597 Guests (See full list)
