JBIRD Posted August 10, 2009 Report Share Posted August 10, 2009 Ok i have two 12 pioneer ts-w308d4s with a RF 501s amp at 4ohms. im wanting to add another pioneer d4 and im wondering if i can run it on the RF amp. the amps says its bridgable at 4 ohms so im guessing ill blow it if the ohm load isnt 4? if so can i get the three 12s to 4ohms. the 2 twelves i have right now are running at 4ohms Link to comment Share on other sites More sharing options...
Laronzo Posted August 10, 2009 Report Share Posted August 10, 2009 Ok i have two 12 pioneer ts-w308d4s with a RF 501s amp at 4ohms. im wanting to add another pioneer d4 and im wondering if i can run it on the RF amp. the amps says its bridgable at 4 ohms so im guessing ill blow it if the ohm load isnt 4? if so can i get the three 12s to 4ohms. the 2 twelves i have right now are running at 4ohms If I'm reading this correctly, your wanting 3 dual 4 subs wired to your amp bridged, and your amp is only stable to 4 ohms bridged. Three d4 subs will end in either .66 load or 2.66, either which will not go very well with the amp you have. Good luck, Larson Link to comment Share on other sites More sharing options...
