younggun69 Posted August 11, 2009 Report Posted August 11, 2009 Ok so I have a spare lvl4 15 sitting around and I want to put it in a t-line. Is it possible to build one that is 48l x 25h x 16.75 deep? I need to have about 10-11ft of port length. The port needs to be about 15x10.75. Any help is appreciated! Dale - 'When life hands you lemons--make lemonade, THEN find someone whose life has handed them vodka and have one heck of a party....lol'
siucsaluki11 Posted August 11, 2009 Report Posted August 11, 2009 the math says no. For the dimmensions you gave me biggest box i can come up with is 9 cubes internally before port or sub. The constant port area needed is over 1 sq. ft. 1 sq ft x 1 ft = 1 cube. You need 12.3xxx cubes INTERNAL for yours, thats not counting all the wood that the port winds back and forth between. It wont happen, the numbers say so, sry. woman..cant live with em...cant shoot em...guess were all fucked You might be a Redneck if you use your leftover gutters for a speaker box port... YOU JUST LOST THE GAMER.I.P. Blazer=========================Last setup was in the 141s on music (37hz) with 2 12s and 1kw in a 4dr blazer.2010 Mitsubishi Lancer DE2 12in Clarions (kept from blazer)HiFonics BRZ1700.1d (at 2 ohms BLOWN) [JBL GTS180X for subs currently 60wRMS x2ch!!!!!! This works for till i get the blown amp fixed] Alpine 4ch salvaged from blazer (currently near death)9887 peerless 7s in the doors and CDT tweeters ran active no speakers in the rearKintik HC1400 under the hood.metered once a while ago, dont remember it...was piss poor compared to the blazer, mid 130s i think....looking to replace subs and amp when i have money.
creyc Posted August 11, 2009 Report Posted August 11, 2009 technically the "port" doesn't need to be quite as big as the drivers Sd... With quite a bit of research and careful planning it might be possible, but it would be very, very tight! 2001 Chevy Blazer (2) SAZ-3000Ds (2) custom 18" Madmax subs in a second row wall Rockford 600-4 Pioneer PRS components Pioneer P800PRS deck
