L 7 squared! Posted August 12, 2009 Author Report Share Posted August 12, 2009 Okay I looked at my amps So if I am thinking right they have inputs an outputs on each. So if I run into one and out from that one to the other input it should work right!?And as for the remote gain splitter I think I may have to get that from Kicker.....? I don't want unecessary wiring. 2x Kicker L 7 15's 2x Rockford Fosgate p 1653's 1x dual center slot ported 5.25cubes tuned 48hz music box 2x Kicker zx1000.1 D's 1x Kicker zx350.4 Remote gains 1x kinetik hc800 1x Kicker 0 guage Sony hu Stock alt : ( A hobby turned into obssession ! Link to comment Share on other sites More sharing options...
raw754 Posted August 12, 2009 Report Share Posted August 12, 2009 Correct... Run 1 set to amp for front highs amp - Run another for rear highs amp - and run final set to input on Sub amp#1, then run set from output on amp#1 to input for amp#2 adjust gains and you are set!!! Link to comment Share on other sites More sharing options...
Austin175 Posted August 12, 2009 Report Share Posted August 12, 2009 was that intended for me or him kia spectra 4 door HU-a kenwood kdc-692x optima red top under the hood ( kinetik battery or powermaster in the back ) Iraggi 260amp H/O alternator 1 set of knu kandy 1/0 guage wiring kit ( 2 more sets coming ) front speakers - back speakers - 2 12" lv 4's with lvl 5 softparts ( going to be 4 in near future) Sundown 3500d( going to be 2 sometime ) i have boughten from - Bass14(smd), ddbump(caraudioclassifieds) Link to comment Share on other sites More sharing options...
raw754 Posted August 12, 2009 Report Share Posted August 12, 2009 For anyone... Like someone else said, if you mix the stereo rca's then sound will be equal in front and back, thus killing front stage completely... If you want to run 2 sub amps, is where the extra connection came in... Link to comment Share on other sites More sharing options...
CLNFREAK Posted August 12, 2009 Report Share Posted August 12, 2009 I know my one amp has a uninteruped out, so if I run from that amp to another amp it is the same as a "Y" and two rca. then adjusting the gains on the first amp dosent affect the output signal. make sense ? Link to comment Share on other sites More sharing options...
raw754 Posted August 12, 2009 Report Share Posted August 12, 2009 I know my one amp has a uninteruped out, so if I run from that amp to another amp it is the same as a "Y" and two rca. then adjusting the gains on the first amp dosent affect the output signal. make sense ? Right... It's just a "pass thru" rca output, no x-over, and the gain setting effects it in zero way. Link to comment Share on other sites More sharing options...
Austin175 Posted August 12, 2009 Report Share Posted August 12, 2009 For anyone... Like someone else said, if you mix the stereo rca's then sound will be equal in front and back, thus killing front stage completely... If you want to run 2 sub amps, is where the extra connection came in... oh ok but i just wanted to know since i have 3 sets of rcas rear front an sub on my deck if i could just run the sub to my sub amp the front to my front amp an my rear to my rear amp kia spectra 4 door HU-a kenwood kdc-692x optima red top under the hood ( kinetik battery or powermaster in the back ) Iraggi 260amp H/O alternator 1 set of knu kandy 1/0 guage wiring kit ( 2 more sets coming ) front speakers - back speakers - 2 12" lv 4's with lvl 5 softparts ( going to be 4 in near future) Sundown 3500d( going to be 2 sometime ) i have boughten from - Bass14(smd), ddbump(caraudioclassifieds) Link to comment Share on other sites More sharing options...
