I am starting to like the inverted look more and more but was wondering if there was any real clean way of running the wires thats the only downside to me about it.
So if you could post up your pics or pics you have of some inverted subs so I can get some ideas :)
Wouldnt be thehoe92 without teh purple
I am in the same boat man i love the look but would like to know a clean way to wire. hopefully some people will have some
98 Jeep Wrangler
33x13.50 super swamper LTB's
Memphis M3 15"
Memphis MCD1000
Optima yellowtop D34/78
Bass Race 129.9
(LBZ Duramax in the future)
my plan once I get my amps was to run silver coated rod, bent to form along the profile of the sub cage. You can run these rods to a hidden point, then to your wire, then to amp. dont see a problem with it as long as all same gauge and keep any of it from touching. clean, and different :clapping:
if you do a buss bar, like on some battery set ups, you could run rod all the way to your amps as well
Edited by 98crewcab
06 2500hd, 6.0L, 4l80e, 4wd, (muah work truck)
7" BDS HC lift kit
(5) 37x13.5R18 Toyo Open Country M/Ts
(5) 18x10 Moto Metal MO962
tablet in lieu of deck
blue tooth interconnect to soundstream eq (for volume control and bass control)
4 Alpine type r 10's
6 cubes net, 80sqin's port, tuned to 33hz
2 brutus brx5000.5's
2 pairs 3" polk audio for a pillars
4 pairs polk audio 6.5 comps
1 pair 8" polk audio for mids
2 xspower d3400 batteries
.....learning alot from meade and his circle of some of the baddest installers ive seen- thanks guys, for not being so cocky and posting the way it should be done!
P.S. Thanks Steve....for the demo!!!! loud as fauk!
yeah I was thinking along the lines of running the wire along the basket of the sub so its a little hidden but if you have 2 subs off one amp its tricky to wire them together cleanly.
are yours inverted right now?
EDIT: duh its in your sig but that looks pretty clean as it is.
Edited by thehoe92
yes, but only running regular, actually 10g extension cord, to them. will use the rod to a buss bar kinda set up once I get my amps. inverted subs in my sig.
7" BDS HC lift kit
yeah I am pretty curious to see this rod idea you got going on.
and I knew it looked like extension cord.
I'll talk to you more tomorrow about your setup
cool beans :good:
7" BDS HC lift kit
  • Who's Online   0 Members, 1 Anonymous (See full list)
