rca splitter
is there a box of some sort or something that can change 2 sets of red/white RCA's into just 1 set? because what i have in my room i have 2 seperate things. a amp and a little cd/radio/player thing. i'd like to have both run off my computer, but i need a splitter so i can have 2 sets running. plus, my H/U in the van has only 1 set of preamp out-puts. i plan on running 2 amps. so how can i do it?
1994 Ford F150 reg cab
2 HFX 12's
Audiopipe APSM-1300
Their called "RCA Y-adapters" and are available at any Radioshack.
My comp setup (Not bad for what it is):
HP Compaq Presario V6120US laptop with:
15.4" widescreen
AMD Turion 64 X2 1.6GHz processor
2x1GB stick DDR2 SDRAM (667 Mhz)
Seagate Momentus 500GB SATA HDD
128MB shared video memory
Windows 7 Home Premium 64 bit
12 cell Lithium Ion battery (actual battery usage time: 6 hours)
What it does:
On a USB 2.0 Wireless card
alright, cool. but is there one for like......2 reds and 2 whites to be turned into just 1 red and 1 white? or how would i go about hooking up 2 amps to 1 set of preamp outputs on a H/U?
2 HFX 12's
Audiopipe APSM-1300
You would have to buy 2 Y-adapters. Turning 2 reds/whites into 1 is not recommended if both are running at the same time or could accidentally run at the same time.
15.4" widescreen
What it does:
then how do yall run like 5 amps off 1 H/U? because if each sub is getting a different amp, how do you do it?
2 HFX 12's
Audiopipe APSM-1300
Lots of amps have pass through. That is an input and an output for rcas on the amp. One set of rcas goes into one sub amp, one set comes out of that same amp and runs into the next amp, another set comes from that amp and so on.
  • Who's Online   0 Members, 0 Anonymous, 988 Guests (See full list)
