14DUB Posted August 16, 2009 Report Share Posted August 16, 2009 Hi all you sundown US lovers I have just bought 2 3000d amps and 2 DC lvl 5 18s and i would like to know how to wier the sundowns up to a DC lvl 5 sub at .70 please, i gather i need to series the DC up but where do the speaker go on the amp as its 2 channel ? Also would it be better to run my rca cable form my head unit and split it to 4 to the 2 amps or link the master to slave??? Your help will be much appreciated ATB Quote Link to comment Share on other sites More sharing options...
Stephen Posted August 16, 2009 Report Share Posted August 16, 2009 http://www.sundownaudio.com/SAZ1000D_1500D_3000D.pdf they are bridged internally, there are only 2 sets of terminals for ease of wiring Quote you can cook bacon shirtless if you're not a pussy...lol not hatin, but am i wrong here it looks as if the amp is not grounded its hooked directly to the battery. it that the way it should be. DC POWER Link to comment Share on other sites More sharing options...
rmzsuzuki89 Posted August 16, 2009 Report Share Posted August 16, 2009 (edited) The SAZ-3000d is a mono amp. There are 2 positives and negatives for ease of wiring, or strapping. What is the coil configuration? EDIT: ^^Beat me to it.^^ Edited August 16, 2009 by rmzsuzuki89 Quote My Feedback Thread http://www.stevemeadedesigns.com/board/topic/103868-official-rmzsuzuki89-feedback-thread/page__pid__1441542#entry1441542 Link to comment Share on other sites More sharing options...
14DUB Posted August 16, 2009 Author Report Share Posted August 16, 2009 (edited) The SAZ-3000d is a mono amp. There are 2 positives and negatives for ease of wiring, or strapping.What is the coil configuration? EDIT: ^^Beat me to it.^^ Yes mona amp with + - + - , DC dual coils .7 any help, and thanks for the quick post! Edited August 18, 2009 by 14DUB Quote Link to comment Share on other sites More sharing options...
14DUB Posted August 16, 2009 Author Report Share Posted August 16, 2009 http://www.sundownaudio.com/SAZ1000D_1500D_3000D.pdfthey are bridged internally, there are only 2 sets of terminals for ease of wiring Thanks for the heads up on the manual link, nice one mate Quote Link to comment Share on other sites More sharing options...
zfrerichs Posted August 16, 2009 Report Share Posted August 16, 2009 bro what happened i thought we had all this settled? series each woofer and hook one up to each amp and call it done or you can series each sub ans strap the subs for a final .7 each amp but i wouldnt recomend strapping amps for someone that doesnt have a lot of experience with higher powered amps just because of confusion of you know what to do and why to do it Quote Roseville, CA Link to comment Share on other sites More sharing options...
14DUB Posted August 16, 2009 Author Report Share Posted August 16, 2009 bro what happened i thought we had all this settled? series each woofer and hook one up to each amp and call it done or you can series each sub ans strap the subs for a final .7 each amp but i wouldnt recomend strapping amps for someone that doesnt have a lot of experience with higher powered amps just because of confusion of you know what to do and why to do it Ye got the series the sub , and then i will have 1 + and 1 - cable, where do i connect or wich of the + - + - terminals i use? i have used more power amps than these mate but just not clued up on the sundowns + - + - set up , and i dont want to blow them up before i instal !! Quote Link to comment Share on other sites More sharing options...
TeamSSC Ron Posted August 16, 2009 Report Share Posted August 16, 2009 Either or . . . just make sure (+)wire/cable goes to (+) amp terminal and (-)wire/cable goes to (-) amp terminal . . . . . Quote TEAM S.S.C. Team Serious SPL Centurions Link to comment Share on other sites More sharing options...
14DUB Posted August 16, 2009 Author Report Share Posted August 16, 2009 Either or . . . just make sure (+)wire/cable goes to (+) amp terminal and (-)wire/cable goes to (-) amp terminal . . . . . AAA.. thanks bro simplesss... Thanks all for the quick help appreciated Quote Link to comment Share on other sites More sharing options...
fritosaregood Posted September 4, 2009 Report Share Posted September 4, 2009 If each sub is a dual .7 you can only wire the sub to .35 or 1.4. I wouldnt put the sub at .35 one a single sundown. Youd have to put either connect a single sub to a single amp at 1.4 ohms, or strap that amps together and series the subs together to get 2.8 ohms the the amps, each amp would see 1.4 ohms. Quote seller feedback: http://www.stevemeadedesigns.com/board/ind...showtopic=61719 http://www.stevemeadedesigns.com/board/ind...showtopic=68281 build log: http://www.stevemeadedesigns.com/board/index.php?showtopic=44800 Gf's build: http://www.stevemeadedesigns.com/board/topic/54346-kickergirls-camaro-new-box-pg-5/#entry753970 Link to comment Share on other sites More sharing options...
