well i went to connect the positive run of wire and as i started disconnecting the battery the alarm kept going off i went ahead and finished disconecting the battery then connected the positive run of wire then as i was reconecting it the battery the alarm started going off again then i tightened it all the way then waited for the alarm to go off then i tried to start the car and only the battery will go on it wont click or anything when i take the key out the alarm beeps
what do i do?
Edited by cthedinger
You shoulda unhooked the ground the battery first before you started hooking up the positive wire.
2000 White Ford Ranger
5" RCD lift
33x12.50 Mickey Thompson MTZs on 16x8 Mickey Thompson Classic 2s
Euro Altezza tail lights
5% window tint
Clarion Indash
4 Q Power 15s
1 Sundown 2000
1 DC power 300 amp alt(on the way)-soon to be 2
2 powermaster d925s batteries
Second Skin Deadener
Highs/mids amp-Crossfire 404
Door speakers-2 5x7 mb quarts and 1 5 1/4" black max up front, stock 5x7s in the rear
Soon to Come:
Lots of SA-8s
2 Sundown saz 3500s(possible 4500s)
5-7 d3100 batteries
custom clamshell
BNC 8s for mids
undecided tweeters
what brand alarm is it.did you try pushing the disarm button :01nocomment8so:
idk it is just the one that come with the car
yeah i realize that now i never did it with my old car and it was fine so i didnt think to do it with this car
any ideas on how i can get it to start?
is it factory or aftermarket .if its aftermarket find the valet switch and put it in valet it should start . and it shouldnt matter if you disconnected the ground first either way the alarm lost power and needs to be reset.
