Installing Stinger Voltmeter
Just wondering if I should just install it from the head unit, i.e. the power/remote and ground it from there OR run wires from the amp's power/remote/ground and use those instead.
I ran the power straight from my battery and hooked the remote and ground to my head unit
Any difference than from the amp? Also, where should I test voltage before installing the volt meter and then comparing and adjusting the volt meter after.
Depends, if you want to what voltage your amp is getting then wire it back there and test your voltage there to calibrate it, but if you want to know your battery voltage wire it there and calibrate off the battery.
MULTIMETER FTW
Well, I'm trying to find out how much drop in voltage I have when I turn my music up. Just not sure where to install it/test it.
  • Who's Online   0 Members, 0 Anonymous, 1063 Guests (See full list)
