Hello all I just installed my mids and Highs and I got a new amp and wanted to know what frequecy I should use for the mids and highs as it goes from I think 50hz to 500hz where should I have it for mids and Highs thanks
Josh
Posted (edited)
do u have a crossover for them. are they comps or are they coaxials?
Edited by finkster
DAT 4125------>RE XXX comps active
Eclipse cd7000
I serve drunks for a living :D
which ones? look up the specs online and then adjust accordingly.
Eclipse cd7000
So im assuming that the setting your talking about is the low pass filter, If you are using the crossover that came with the speakers I would just let it handle all the crossover points and slopes. Leave the amp setting at 50hz so you are giving the set as close to a full range signal as possible.
Too Much Stuff to list .
I am using http://www.poweracoustik.com/pa2006/produc...O_amp_stax.html
1250/2
and I am using the HPF on the amp as well when I move it to 50 is seems to have more bass as I wand to limit some of that out I have the know straight across towards 500hz
