I have a 2000 2.2 ecotec cavalier and in this forum it mentions i could replace my stock cs130d alt for a ad244 alt. in the tutorial it only mentions it working for 4.3 liter s10's, blazers and so on. Well i believe my stock alt is a cs130d which puts out only like 45amps at idle and 105 at some rev point and the new ad244 comes in two sizes 130 and 145amp which was supposivly proven to do 100+ at idle (500-600) engine rpm. Could someone help me and see if this alternator infact will work for me?
Link to alt tutorial
I would like to upgrade the new alt with this if i need even more power.
alt upgrade kit
2010 Silverado
18" DC XL 18
DC 2k
XS Power Batts
somebody?
If two of the bolt mounts matchup it should work so i guess ill ill just buy one and try it out when i get the chance.
2010 Silverado
18" DC XL 18
DC 2k
XS Power Batts
Check j-body.org.
you may have to change the plug on the alternator. maybe not.
I'm going to be putting a AD244 in my Blazer, but its a 4.3.
I believe on JBO theres are guide for it.
Planning to do the same thing with that H/O rebuild.
I think if just one mount was missing whats the problem it should work right still? Id just need a belt is all i think. ill try it when i get the cash.
2010 Silverado
18" DC XL 18
DC 2k
XS Power Batts
Powerbastards makes a 220amp cs130d that will probably just bolt right in your car. Check them out.
98 Toyota Camry
Eclipse AVN-6600
AudioControl 3.1
AudioControl Epicenter
US Amps AX2000
US Amps MD-43
1 set Alpine type X components
1 set RF Power components
1 12" RE Audio XXX
220 Amp Iraggi Alt.
Red Top (Front)
Kinetic HC-600 (Back)
Second Skin Damplifier Pro
I few people told me to stay away from the cs130d because its a small case and heats up very quick which isnt very good. they may be wrong tho idk. i just want something better then i got till i can get a 270xp.
2010 Silverado
18" DC XL 18
DC 2k
XS Power Batts
  • Who's Online   0 Members, 0 Anonymous, 3609 Guests (See full list)
