Anybody ever tried to use the small distribution blocks in a enclosure so that you can run 1- 4 gauge from the amp to the inside of the box to the block which splits it up to 4-8 gauge.I am gonna run 4-dc audio level4 xl subs and I have these distribution blocks lying around.Would this work or is it a dumb idea?
2001 Southern Comfort Suburban sittin on 26"s
Eclipse 6620 double din head unit (2004 dash mod)
4-AQ 3500D amps @1 ohm
8-Cadence 6.5 midbass 4- in each door.
Image Dynamics Cd 1 pro HLCD
4-runs of KnuKoncepts 1/0 power wire
4-DC AUDIO lvl 4 xl 18"s in a wall
2-MECHMAN 270 AMP alternators(2 more on the way)xs power VCM
7-Deka intimidator group 31 batts(soon to be Xs power)
2-Rockford Fosgate Prime r300.4(1 bridged on mids, 2nd on CD1 horns and rear door speakers)
1-Rockford Fosgate 360.2(operated by Palm tungsten T5)My link
yes it would work but what amp do you have that accepts 4 gauge for the subs
i was thinking leave the 12 sitting in the box in the hole and duck tape from the bottom of the sub to the bottom of the baffle so the sub doesnt free air. would that work?
A T15K? :01nocomment8so:
My comp setup (Not bad for what it is):
HP Compaq Presario V6120US laptop with:
15.4" widescreen
AMD Turion 64 X2 1.6GHz processor
2x1GB stick DDR2 SDRAM (667 Mhz)
Seagate Momentus 500GB SATA HDD
128MB shared video memory
Windows 7 Home Premium 64 bit
12 cell Lithium Ion battery (actual battery usage time: 6 hours)
What it does:
On a USB 2.0 Wireless card
maby a 4guage to 8 reducer, but i was thinkin the same thing, would make it a hell of alot easyer to run 8guage to subs, but some ppl just use all thread rod goin into box to bolt speaker wire to,
but a dist block will work, but dont trim away strands to make it fit, get a 4guage to 8 reducer like this
http://www.darvex.com/PAC48S/Sound+Quest+4...ge+Reducer.html
here's a link to my system 99 toyota tacoma , 2 mtx 8000 1504's in a sealed downfire , 1000w memphis amp
here's a link to my other system my 90 geo prizm test car
heres a thread i got of new songs u can dl that are legal = Some Good Bangage/you Can Dl These Free And Legit
haha, can u amagin someone usein step downs raise from amp to 4guage n then step down to 8 n go into subs, talkin bout over kill lol
im talkin str8 wireing not a dist block
Edited by tacomabanga1986
I would probably use a step down or solder the 4 gauge and grind it down .I was wondering because I have seen a lot of guys run 8 gauge out of the amp and attach it to the bolts on some boxes and run 2 and sometimes 4 times to go to the subs. I would think that splitting 1-8 gauge into 2 or 4 is not efficient.
Nothing reaaaally wrong with splitting 8ga. You're talking ~5kw before 8ga starts to get to small IMO.
Bolts and lugs, cheaper than distro blocks and just as good.
10.x volts fo' life!
  • Who's Online   0 Members, 0 Anonymous, 1989 Guests (See full list)
