Hostility Posted September 1, 2009 Report Posted September 1, 2009 is it worth using a line driver on a 4ch amp? or will it make no difference at all? 99 s10 4.3L Big 3 220amp alt Odyssey 1500 Odyssey 2150 Northstar NSB 75 Sundown Audio 3500D Sundown Audio 125.2 3 Sundown Audio SA-12's Alpine H/U RF Power Comp set 6.5" RF 3 sixty line driver 5.25 cubes @ 31hz
L 7 squared! Posted September 1, 2009 Report Posted September 1, 2009 I put one on my monos and it worked great. Dunno bout a 4 though good question. Anybody know for sure??? 2x Kicker L 7 15's 2x Rockford Fosgate p 1653's 1x dual center slot ported 5.25cubes tuned 48hz music box 2x Kicker zx1000.1 D's 1x Kicker zx350.4 Remote gains 1x kinetik hc800 1x Kicker 0 guage Sony hu Stock alt : ( A hobby turned into obssession !
Hostility Posted September 2, 2009 Author Report Posted September 2, 2009 I put one on my monos and it worked great. Dunno bout a 4 though good question. Anybody know for sure??? yea i was going to order either the RF line driver for my mono, or the AQ matrix if its worth putting it on a 4ch also. 99 s10 4.3L Big 3 220amp alt Odyssey 1500 Odyssey 2150 Northstar NSB 75 Sundown Audio 3500D Sundown Audio 125.2 3 Sundown Audio SA-12's Alpine H/U RF Power Comp set 6.5" RF 3 sixty line driver 5.25 cubes @ 31hz
finkster Posted September 2, 2009 Report Posted September 2, 2009 a line driver is only necesary when your head unit doesnt put out enough voltage. its usually used when powering several amps rather than just one. which alpine do you have? It wouldnt hurt to have one, but you could save some cash by not running one. DAT 4125------>RE XXX comps active Eclipse cd7000 I serve drunks for a living
Hostility Posted September 2, 2009 Author Report Posted September 2, 2009 a line driver is only necesary when your head unit doesnt put out enough voltage. its usually used when powering several amps rather than just one. which alpine do you have?It wouldnt hurt to have one, but you could save some cash by not running one. well i checked and im not even getting 2 volts at my listening level or above. and its rated for 4. buying a new headunit but i still dont like how low it is. i may just get one for my mono to start with. 99 s10 4.3L Big 3 220amp alt Odyssey 1500 Odyssey 2150 Northstar NSB 75 Sundown Audio 3500D Sundown Audio 125.2 3 Sundown Audio SA-12's Alpine H/U RF Power Comp set 6.5" RF 3 sixty line driver 5.25 cubes @ 31hz
