kerfing
uluahunta808
well before i ruin a sheet of mdf is there anything i need to know about doing kerfing. i plan on rounding the corner that leads into the port. this is gonna be my first time so all the help is needed.
cut very very very very very very very very very very very close.
if you cut a few practice sheets (which i recommend) and they crack instead of bend- YOUR NOT CUTTING DEEP ENOUGH!
take your time, check your math twice, and dont end up like me.......
name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src="
type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="425" height="344"></embed></object>">
type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="425" height="344"></embed></object>" type="application/x-shockwave-flash" width="425" height="350">
-Drew
uhoh_45 said:
drill holes as deep in your back cuts helps release air pockets when you fiber glass it, you can also do it with sonotube and fiberglass if your just doing the end of the port.
J&T DESIGNS
M5
4 Audioque 15's copper coils dropping Audiopipe, and picking up DB DRIVE OKUR
Powermasters
XS POWER
Dropping MaxxSonics
Pioneer
  • Who's Online   1 Member, 0 Anonymous, 9954 Guests (See full list)
